Mk2kompressor
Post by Mk2kompressor »
Done some more stuff
2.Slow
Cadz09
Post by Cadz09 »
That head liner looks smart, what did you use, dye or spray? I just had to replace my lower side runner too, alot easier then I expected it to be.
Papa Bear
Post by Papa Bear »
Black
Marmite lover!!!
VCDS
Mk2kompressor
Cadz09 wrote:That head liner looks smart, what did you use, dye or spray? I just had to replace my lower side runner too, alot easier then I expected it to be.
Sprayed the headlining with cheap satin black and trimmed the shelf with some material Image
2.Slow
Cadz09
Post by Cadz09 »
Ah decent, came out well, I'll look into this
Ripley55
Post by Ripley55 »
Was going to head out to the Bottle bank to get rid of all her empty bottles of Pinot Grigio Image and then a clean Image
Van hasn’t liked sitting for 3 weeks Image Battery flat as a you know what, and my jumper pack also Image
Ripley55
Post by Ripley55 »
Chaps
Need some advice. Charged the car and have taken for a spin, and all good. I now have engine light on ? It’s not misfiring, any ideas please ? Is this due to battery going completely flat perhaps ?
Cheers for some advice
@Ripley55 hi mate, my battery has died a few times and never had the engine light come on, mine has been on ever since I overfilled the adblue last time though lol
Ripley55
Post by Ripley55 »
Ahh @gazza31112
Strange coincidence, as 3 weeks ago I filled up with Adblue as well, and may have put a drop too much in as well, but didn’t notice a light afterwards, and obviously haven’t been anywhere, can it just be cleared on ignition, or is it VCDS scan and reset ?
I tried to clear mine but it just comes back, apparently from what I have read the sensor needs recalibrating, you can only refill the amount it says on the dash, I just filled until it overflowed, which apparently confuses the sensor.
Not certain of this, it's just what Iv read.
I haven't bothered to get it checked as my warranty has just run out lol, Iv got a fault code of failure to read NOX sensor b, I assume that's something to do with adblue, but still runs fine.
And my light came on 2 days after I filled with adblue, not straight away
Ripley55
Post by Ripley55 »
That’s it then ? Is it a code it mod, or will it reset automatically once level drops ?
Mine hasn't reset, I'm now down to 3000 miles remaining on adblue, and it's still on.
I assume it has to be done by VW.
Oldgregg
Post by Oldgregg »
[mention]Ripley55 [/mention] The sensor may need replacing or resetting/ recalibrated. From what I’ve heard if you delete the fault code it just comes back. If it’s to do with the NOx sensor that is.
sheepy92
Post by sheepy92 »
@Sean1066 Hi sean where did you get the adaptors for back of vents mate could do with some of these myself are they 3d printed
