Rhodesian75 wrote: ↑Sat Feb 29, 2020 6:06 am
Had a set of genuine wind deflectors fitted and they look awesome.
I have them too, like them a lot. The Mk4 ones (which you got if you bought them recently) are a bit better than the Mk3 ones (better plastic, bit more streamlined). If you ever replace them, fit them yourself, takes about 5 minutes, the instructions are in the box.
gazza31112 wrote: ↑Sat Feb 29, 2020 6:29 am
Peel off some 3m backing and push a metal clip into a window seal
OEM ones are even easier. Use provided tool to push some plastic clips into the window seal. Job done.
gazza31112 wrote: ↑Sat Feb 29, 2020 7:10 am
Over here hekos are under £30, they take 5 mins to fit, still seems steep to me
If you can even find non-OEM ones on the other side of the world ("Rhodesian75" and myself are), they would work out to be pretty expensive. The VW ones don't have any branding on them, which I prefer. Mine cost about £70, fitted them myself.
