That’s the gla spec I’ve found
Centre bore : 66.6
Diameter : 17 - 19
Width: 215 - 235
Alloy Wheel Size Guide
Mcclean
- dan@biali
Re: Alloy Wheel Size Guide
Have a look on here https://www.wheel-size.com/size/mercedes/gla/. Looks like Merc pcd is 5x112 so in theory GLA wheels could fit, all comes down to the overall specs i.e offsets and width (in inches, not the mm you have found as thats the tyre size although that will come into it) are probably the most important to get right but diameter and shape of spokes for brake caliper clearance are also important. The centre bore on the Mercedes wheels means you will need spigot rings to reduce the size down to 57.1mm.
Lifecaddy
Very helpful - thanks
