rich181
Post by rich181 »
You would need to drill extra holes, and cut off the feet/spikes (can’t think of the proper word).
deany123
Post by deany123 »
rich181 wrote:Image
I need to get myself some of these they look the nuts Image
rich181
Post by rich181 »
They are also heated. That’s a future mod though, other things to do first.
Matias
Post by Matias »
Very nice seats. I want fit better seats then I have. But I have ori 7 place small car. And I want have all seats the same. But only 6+7 place are in ori. But I haven't this inside. Only for technical check controll every two years.
Dimension of seats holder is for me new imformation. I mean only about different hole. I modify caddy holders for touram seats with welder and drill machine.
Sent from my LLD-L31 via Tapatalk
VW Caddy Maxi Life 180 HP
james400
Post by james400 »
Modified my inner rear wheel arch trims 4h down and got one done ImageImageImageImageImageImageImageImageImage
Post by Stedlocks »
Bought another can of paint.... in case I want to do something!!🤣
hef355
Post by hef355 »
@james400 love those rear coilovers J mate, what are they?
C Chis
Post by C Chis »
Today was fit cruise control day... easy to install using the “how to” in the tech section.
The air bag clips were a bit of a fiddle to release, but straight forward once you see how it works and you get the screwdriver blade in the right bit!
Fitted 2 replacement stalks, cruise and and the SWCM (CQ variant-cost saving) plan to upgrade to multi function steering wheel and high line instrument cluster once I’ve tracked down the parts for a reasonable price
No error codes, no faults! Image
r1lea
Post by r1lea »
CQ is midline, the most common and easiest to get hold of is CH which is highline for the mfsw upgrade
C Chis
Post by C Chis »
Hi [mention]r1lea [/mention]
Yeah, didn’t want to spend the money on a CH module at the moment so I went midline I reckon it’ll be a while before I upgrade to a MFSW
However, if I see one one at a really good price I’ll most likely buy it and fit it
Strath25
Post by Strath25 »
While my toddler napped I got some time to tidy up my rear brakes..Image
james400
Post by james400 »
Been making some bits thought I'd make some blanks for the scuttle panelImageImageImage
R8umar
Post by R8umar »
Looks great, what 3d printer you using?
james400
Post by james400 »
Gucoco a3 printer still learning tho
@R8umar
Was the quote of the previous post absolutley necessary? I think a replay without quote would suffice!
