Vwjack88
Posts: 237 Joined: Sun Oct 07, 2018 1:08 am
Post
by Vwjack88 » Tue Apr 21, 2020 1:17 pm
My tiny little job for the day on the van. Popped these little beauties in. Looks better
tonyhill
Posts: 652 Joined: Sun Feb 08, 2009 2:57 pm
Post
by tonyhill » Tue Apr 21, 2020 2:28 pm
^^^^ If it wasn't for the little triangle window, you'd swear the white van was a mk4
Humphreys2006
Posts: 14 Joined: Tue Jan 07, 2020 5:24 pm
Post
by Humphreys2006 » Tue Apr 21, 2020 5:17 pm
I took all my ply lining out ready to put sound deadening in and found loads of 10mm holes in the van floor
. No wondwring whats best to cover them all with
Posts: 1566 Joined: Sun Oct 08, 2017 6:12 pm
Post
by Stedlocks » Tue Apr 21, 2020 10:31 pm
Continued prepping the caps ...
In my fantastic spray booth, I laid down the primer man...
tomorrow, I base coat and lacquer....! Hopefully, while they’re drying, whip the door cards off (he says, all casual like) and put the new bases on.... plus other stuff!
Mattyh606
Posts: 77 Joined: Mon Mar 16, 2020 9:12 pm
Post
by Mattyh606 » Wed Apr 22, 2020 6:47 am
Humphreys2006 wrote: I took all my ply lining out ready to put sound deadening in and found loads of 10mm holes in the van floor
Foil tape and then your sound deadening pal
Sent from my SM-N976B using Tapatalk
Humphreys2006
Post
by Humphreys2006 » Wed Apr 22, 2020 10:46 am
Mattyh606 wrote: Foil tape and then your sound deadening pal
Thanks mattyh606
ajjoyce
Posts: 45 Joined: Mon Mar 09, 2020 10:13 am
Post
by ajjoyce » Wed Apr 22, 2020 8:25 pm
Fitted reverse camera. New knobs for heater controls and wired up a wireless charge to sit in the cubby below the ashtray
Sean1066
Posts: 1687 Joined: Wed Oct 24, 2018 11:01 pm
Post
by Sean1066 » Wed Apr 22, 2020 8:39 pm
james400
Posts: 1199 Joined: Sun Sep 17, 2017 8:35 am
Post
by james400 » Wed Apr 22, 2020 8:51 pm
Started to flush my rear doors one door at a time no rush lol will carry on 2moz
Barrington
Posts: 79 Joined: Sat Feb 08, 2020 8:36 pm
Post
by Barrington » Wed Apr 22, 2020 8:54 pm
@ajjoyce did you have to put a relay on to make the reverse camera work clearly I'm having a nightmare with mine
ajjoyce
Post
by ajjoyce » Wed Apr 22, 2020 9:01 pm
No mate I taped into the rear wiper. It is currently permanently live with ignition. I will be looking at taping into the reverse for the switch signal but that’s a job for tomorrow
Barrington
Post
by Barrington » Wed Apr 22, 2020 9:08 pm
Ahh I don't have a rear wiper
Ant bliss
Posts: 141 Joined: Mon Jan 07, 2019 7:43 pm
Post
by Ant bliss » Wed Apr 22, 2020 9:59 pm
Started to paint my calipers yellow,now got even more reason to get some spax coilovers
Post
by Stedlocks » Thu Apr 23, 2020 12:13 am
One flipping wing mirrors...!
It looks good, but you need to be a gynaecologist to get the radio aerial through the hole!!
Posts: 5163 Joined: Sat Feb 18, 2017 10:52 pm
Post
by the swan fiend » Thu Apr 23, 2020 7:52 am
@Barrington. What is it exactly that you’re struggling with mate? I’ve done a rear cam install and I may be able to help.
@ Pat, nice work mate. They look good
