Vwjack88
Post by Vwjack88 »
My tiny little job for the day on the van. Popped these little beauties in. Looks better ImageImage
tonyhill
Post by tonyhill »
^^^^ If it wasn't for the little triangle window, you'd swear the white van was a mk4 :)
Humphreys2006
Post by Humphreys2006 »
I took all my ply lining out ready to put sound deadening in and found loads of 10mm holes in the van floor . No wondwring whats best to cover them all with
Post by Stedlocks »
Continued prepping the caps ...
In my fantastic spray booth, I laid down the primer man...
😂 tomorrow, I base coat and lacquer....! Hopefully, while they’re drying, whip the door cards off (he says, all casual like) and put the new bases on.... plus other stuff!
Mattyh606
Post by Mattyh606 »
Humphreys2006 wrote:I took all my ply lining out ready to put sound deadening in and found loads of 10mm holes in the van floor Image. No wondwring whats best to cover them all with
Foil tape and then your sound deadening pal
Sent from my SM-N976B using Tapatalk
Humphreys2006
Mattyh606 wrote:Foil tape and then your sound deadening pal
Thanks mattyh606
ajjoyce
Post by ajjoyce »
Fitted reverse camera. New knobs for heater controls and wired up a wireless charge to sit in the cubby below the ashtray
Sean1066
Post by Sean1066 »
Well yesterday I finally finished the sanding and prepping my rear bumper Image
So today when I got in from work I thought I would prime it read for the paint shop for them to do there fantastic work and paint it Image
There are probably some imperfections but the paint shop should get rid of them Image
Caddy maxi 3.2 VR6 EX BG
My build thread
james400
Post by james400 »
Started to flush my rear doors one door at a time no rush lol will carry on 2moz ImageImageImage
Barrington
Post by Barrington »
@ajjoyce did you have to put a relay on to make the reverse camera work clearly I'm having a nightmare with mine
ajjoyce
Post by ajjoyce »
No mate I taped into the rear wiper. It is currently permanently live with ignition. I will be looking at taping into the reverse for the switch signal but that’s a job for tomorrow
Barrington
Ahh I don't have a rear wiper
Ant bliss
Post by Ant bliss »
Started to paint my calipers yellow,now got even more reason to get some spax coilovers
Post by Stedlocks »
One flipping wing mirrors...!
It looks good, but you need to be a gynaecologist to get the radio aerial through the hole!!
@Barrington. What is it exactly that you’re struggling with mate? I’ve done a rear cam install and I may be able to help.
@ Pat, nice work mate. They look good
