- Matias
Hey,
U have any holes in front bumper. :-)
Joke.
Joke.
VW Caddy Maxi Life 180 HP
- Boonalon
They do look smart, you have it stripped for paining?
shameus
- Boonalon
Ah nice
another agri spec
if your stuck for paint, we are in work on Wednesday to finish up a few Garda cars, I could get the lads in the body shop to mix up some paint
PM me if needed
another agri spec
if your stuck for paint, we are in work on Wednesday to finish up a few Garda cars, I could get the lads in the body shop to mix up some paint PM me if needed
shameus
I think my guy is getting some delivered... whoever decided van mods isn't an essential service needs their heads checked
- Matias
Shameus:
Nice colour of Yours car.
Sent from my LLD-L31 via Tapatalk
- Matias
Painted of rear door handle.
I hope if I make all works what I can during corona hollidays.
Br Matias
Br Matias
DW2207
With lock down still in place I managed to complete several jobs on the van
Front & Rear new brake discs and pads. Opted for ebc ones, went for the 312mm upgrade for the front and stick to the standard 256mm on the rears plus new ultimax pads from them as well. Seem a lot better than the cheap ones that someone had fitted previously. Plus fluid change.
Fitted new Skoda Octavia vrs front calipers to replace the corroded old ones, direct fit if you have the correct size hub, do not need to extend the brake lines either.
New master cylinder, what a ballache that is to do haha.
The Touran door card modification, gives the interior a nicer feel to it, a dremmel cutter comes in handy when cutting around the wing mirror black plastic covers.
Like all things you repair one thing and another breaks
Next job is to replace the radiator as this is now leaking, surrounding pipe joints are bone dry, I will try and document this as I could not see a how to on this, if folks like.
Last of all, scan the van to see why my glowplug light is flashing, last scan showed a dtc, pointing to the brake light switch which I did not plug in correctly, so I’m hoping it’s not this.
Keep safe people
Dan
Keep safe people
Dan
DinoBino68
Hey loglifter,
I'm interested in doing a similar fit in my Caddy and was wondering where you sourced the arm rest/center console from and was it from a Caddy or other VW model?
Aso dig those seats.
Cheers, Dean
Rather be cruising in my Caddy
VW Caddy Maxi British Gas Blue C20 Startline BMT 1.6 TDI
- Matias
Dean,
this armrest is from touran. I have prepair this too.
Can move upped, down, front and rear as U want.
Br Matias
Br Matias
DinoBino68
Looking very nice sir. May I ask how you wired up the USB mod? I like that configuration and was wondering if you used a piggyback fuse spur for the mod if so can you recall which number fuse was used?
Cheers,
Dean
Ant bliss
Removed my leaf springs so I could fit my polibushes on the bench in the garage,
Tomorow fit my maxi arb with poli bushes
- Ripley55
Hi Dean
My original dash tray came factory fitted with a 12v socket outlet, and this would have been fused.
Anyway I removed this tray and unplugged it, and replaced with one from the scrappy's that was plain. I then tapped into the +ve and -ve at just behind the plug for the original 12v socket
I then fitted this unit from Amazon into the new plain tray
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
This unit also came with a 12v socket outlet, which so I replaced with another USB outlet
This second USB outlet came with a cable that was fused at 10A, so I actually used that as well for my feed. That will have a fuse behind it as well from the OEM socket outlet if that makes sense ?
Dave
Dave
ViralEye
Debadged the barn doors.... Was in 2 minds of to do it or not, but isolation and boredom kicked in
Before
After
Sent from my ONEPLUS A6003 using Tapatalk
Before
After
Wallie
Getting rid of 7 years worth of british gas grime:
