Cruise Control - 2012 2.0 4motion Manual Maxi
Robin UK
Post by Robin UK »
Hi, I've been trying to find a supplier for aftermarket cruise control kit for my Caddy Maxi, but all of the reputable looking ones on Ebay are for 2010 or younger, and I can't find one, including the cable which appears to be required to go to the ECU, for my model. Can anyone point me in the right direction?
I've also seen that some ECU/Modules can need replacing. Where do I find the code for mine to check if this is the case?
I've not yet been granted access to the majority of the forum to be able to check the threads there.
Thanks,
Robin
Current: 2014 Caddy Maxi Life 2.0 TDi DSG 140ps
Previously: 2012 Caddy Maxi Life 2.0 TDi 4motion 110ps
Maxi4life
Re: Cruise Control - 2012 2.0 4motion Manual Maxi
Post by Maxi4life »
It's all in the how to section, a whole thread dedicated to it.
Sent from my SM-N910F using Tapatalk
Robin UK
Post by Robin UK »
I thought as much, but sadly I'm not yet able to access this, was trying to wait until I had access to try and avoid asking, but it's been over a week (since requesting to have my membership upgraded) and it's getting to the point where I really want to get it sorted before a trip next week.
spacewalker
Post by spacewalker »
get that and problem gone
https://www.youtube.com/watch?v=JQ8cBbe ... e=youtu.be" onclick="window.open(this.href);return false;
fxy
Post by fxy »
iv just put these stalks on cruise and MPG,RANGE and activeated through VCDS and it works,
go off the part numbers
http://www.ebay.co.uk/itm/201623130459? ... EBIDX%3AIT" onclick="window.open(this.href);return false;
Robin UK
Post by Robin UK »
Hi fxy, is your's a 2011-2014 model?
Robin UK
Post by Robin UK »
Managed to find one on ebay (marked as for Golf MK 6 2011 onwards) for not as cheap as that, but for nearly 1/3 what I could get from one of the VAG Retrofit shops, hopefully fitting it won't be too bad! I'll find out tomorrow.
fxy
Post by fxy »
yeah mines a 2011,
fxy
Post by fxy »
http://www.ebay.co.uk/itm/VW-GOLF-PLUS- ... Sw44BYGc7a" onclick="window.open(this.href);return false;
iv found this 1
Robin UK
Post by Robin UK »
Thanks for looking, I think I'd seen that one earlier, but there's something weird with the listing, every time I look on it it says it's been removed, even though it comes up on the search still. I've ordered one now anyway (although about twice as much as your's as apparently it's genuine and new), so hopefully it'll work!
duduk
Post by duduk »
Robin,
Please let us know if it works. I am also interested in the problem.
Robin UK
Post by Robin UK »
Hi duduk, the cruise control works, however it has stopped the MFD toggle control working. I'm not sure if this is due to me plugging in a cable wrong (or not), or something in the coding, but I have heard hints that there is a caddy specific version of the part I've ordered which has a different right stalk. Going to contact the seller to query this, but won't have a chance to investigate properly for a week or so as going on a trip and don't want to stop the cruise working.
Anyone know about the right stalk? It doesn't appear simple to switch the stalks between the two units, but I haven't tried yet.
Robin UK
Post by Robin UK »
Ignore my previous post. Just went into the coding with the VCDS and turns out somehow my wiper stalk control of the display had been disabled. Ticked this box (in the Steering Wheel section I think) and it's all sorted!
mmbjp
Post by mmbjp »
Just a question on these stalks. Would it work on a caddy that didnt come out with it as standard
Sent from my SM-G920F using Tapatalk
Aikon
Post by Aikon »
I've had cruise retro fitted on Octavia's & A2's with no issue, the A2 needed a wire running from the ecu which the installer made as the genuine article was expensive, his eBay shop is here: stores.ebay.co.uk/hazzydayzltd/
