Just ordered an engine cover and wind deflectors. Bought the van last weekend so I'm skint at the min. Alloys and lowering kit are next on the list
Trying to fit my new mk4 rear lights today, but I cant repin the connector.. Are the wires fitted very tight or do I have the wrong removetool?
Sent fra min VOG-L29 via Tapatalk
- Welp
Put a new engine cover on my 2020 Mk4 Caddy Life. It's a 2l 102.
I bought the cover, oil seal & 2 balljoints from the local Seat dealers. Total cost £152:86
It had a Seat badge covering the VW logo. It was stuck on with self adhesive tape so it easily came off to reveal the VW logo. The engine looks a lot better and is noticeably quieter up to 30mph. I haven't driven it any faster since putting it on.
The oil seal isn't what I'd call a seal. It fits around the rim where the oil filler cap is, to prevent spills onto the engine.
Part nos in the Seat records:
Cover: 04L 103925S
Oil seal: 04L 133287
Balljoint 03L 103164 (need 2 of these. The other balljoints were already fitted on my engine.
The parts were a perfect fit - no need for brackets etc.
Cover: 04L 103925S
- Papa Bear
Test Fitted roof cross rails.
Nothing special and not for heavy loads but perfect for what we need occasionally.
A whopping £29.99
A whopping £29.99
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- Cabbs
[mention]Fat Eric [/mention]
Hi Mate,
The front is a hybrid MK7 GTI/caddy bumper. Basically there the top half of a caddy bumper and bottom half is MK7 GTI. There are various people
Who make them but they don’t come cheap.
The rear is a R32 bumper and there on eBay mate.
Hi Mate,
- Ripley55
Bought some new wheels to try
Want to give 18’s a go. Found a nearly immaculate set of Audi OEM 8Jx18 ET40, with 2 brand spanking newBridgestone’s, and 2x Bridgestone’s with 7mm tread on, at an Audi Main dealer. (ex demonstrator). One of the Alloys has a tiny mark on it, the rest are perfect cheap as chips
@cabbs
Just a standard r32 rear? And if so what age. Cheers
- Cabbs
[mention]Jono1 [/mention]
No mate. One of these. You need to bond the inner brackets from your original bumper into this one.
https://www.ebay.co.uk/itm/284163843028
- maxx007at
It is the correct tool, but did you take out the securing tab? It’s kinda purple color and slides out to the side of the connectorenwo wrote:Trying to fit my new mk4 rear lights today, but I cant repin the connector.. Are the wires fitted very tight or do I have the wrong removetool?
Reason: removed picture from the quote
Yes, have removed the purple secure tab but it feels like the wires will not come loose
- Cabbs
[mention]enwo [/mention]
Push the tool in further. It feels like it won’t go but it does. That will then release the raised lugs and you should be able to pull the wire out.
- Cabbs
Added some windscreen stickers today courtesy of @doc. I think they look pretty good. Not to loud and in your face. I had to cut off the forum logo though and reposition it otherwise it wouldn’t of sat down the edge as close as planned.
Maybe my tool is to short, because I have pushed it as far as it goes but it still wont moveCabbs wrote:[mention]enwo [/mention]
@enwo. I don’t mean to insult you mate, but are you pushing the tool in from the right end of the connector? The very first time I tried depinning a wire, I was pushing it in from the end where the wires go. Not the flat end that goes into the other plug. I was obviously getting nowhere! I’m a complete novice though.
Was pushing it in from the right side yes.. Figured it out now and it was my tool from ebay that was a disaster.. Instead of pushing in the clips on the connector the tool was so weak that the tool got pushed out instead
