As per title, I pulled the complete cruise control stalks from a Touran 2009 along with clock spring and bottom module and replaced them all into my 2005 Caddy.
I noticed the caddy had an extra steering position module that the touran never had and google-foo says its because its part of the touran clock spring now. Also the steering module didnt have the pins to transfer the module anyways.
Anyhow, cruise seems to work in VCDS and I'm getting the signals from all the switches and clutch and brake pedal, but the van has a yellow steering wheel error now on the dash and I cannot get rid. Both through coding and various diagnostics.
Any ideas?
i THINK the van is expecting the sensor module to still be there and not via the clock spring, but thats just guesswork. I was hoping a matched set from the Touran would be compatible, but I'm missing something. Incorrect coding perhaps?
Perhaps as I still have the Caddy Clocks in and not the Touran ones yet ? Still waiting for a cable to arrive so I can get the Pin numbers and try a IMMO transfer.
Touran parts used...
1k0 959 653 C - Clockspring
1k0 823 248 CQ - Module
1k0 953 519 J - Right Wiper Stalk
1k0 953 513 G - Left Indicator Stalk
Retrofit Cruise and now steering sensor issue
Azzi
