Morning all,
I’ve seen a set of 18” Audi alloys. Hoping someone in the know can confirm if they’re ok to go on my maxi.
The are 8j et39 PCD 112
Also what size tyre are people running on 18s?
Wheel Size Check
- adeybroth
Re: Wheel Size Check
did you ever find this out? ive been looking at a similar wheel set up
Others may be able to chime in on the specific wheels you mention. But in the meantime, have a look at willtheyfit.com. Input your existing setup and your proposed, and it will give you an idea of the differences. You can then take measurements on your van to get an idea of how the new setup will fit. You can also try different tyre combinations to see how overall diameter and speedo error change.
Afaik ET45 is the max that will fit on a Caddy.
Sent from my SM-A546B using Tapatalk
- adeybroth
Well it’s a slow burner this, just picked the wheels up, will fit one on the back see if it fouls anything. But need to change the tyres as they are massive. 245/45R18, be giving the swamper crew a run for their money with those.
- adeybroth
Excuse the dirty van, tried the wheel on the back. No problems with clearance on the sliding door.
