Ex. German Cab/Taxi > 538k and counting Camper/Daily
SmokeyTheBandit
Re: Ex. German Cab/Taxi > 538k and counting Camper/Daily
Post by SmokeyTheBandit »
@stu_b
Im the only one using the van on a daily basis. The entire camper van part will be for me really. I only need to transport my father in his wc every now and then. Thats the reason i cannot go to a dedicated camper van build.
The wc ramp is still fully usable, i made the counter easily removable with two butterfly bolts.
Most of the bed and the full counter will be stored in my attic with the rest of the camping equipment. But i can easily install them when needed.
Yes its using shore power, whenever ill go camping i will mostly go to a small "farm" camping site or something similar. I like the fact that you have easy access to shower/toilets/water and a bit of extra security as i need to keep my expensive EMTB outside :lol:
Regarding the counter and the induction plate placement. The tap and small sink will come on the other side but i will still have a large amount of space to use when they are there.
And yes he is enjoying a nice Belgian Peach Fruit beer 8)
SmokeyTheBandit
I also created an POE (Power Over Ethernet) port in the car. Which im going to use with a wifi repeater (powered over an ethernet port) thats going to be placed on the roof (not permanently obviously :lol: ). That way i should be able to easily receive wifi on every camping site,
As an IT system administrator i had to incorporate a bit of IT equipment in this project ;)
Post by stu_b »
glad your Dad still gets to enjoy a beer
and driven around in style :)
it's nice to have the creature comforts when your camping but not all fit in the caddy - long hot showers, flushing toilets etc but campsites provide an option if you need it
plus you get to meet some pretty nice people
the POE set up looks interesting
maybe you could share it in a how to for others to emulate
Gmancan1
Post by Gmancan1 »
Suppose only reason why not too
But u can get hotspots that have unlimted data meana you have wifi even if your not near
But it costs
Wifi at sites I assume will be free
SmokeyTheBandit
Yes exactly, a hotspot is a nice backup option but not the preffered option really. It will drain your phone battery very quickly and the phone will get rather hot :lol: . And im not talking about the possible extra costs. Wifi would be the best option if it is available.
Gmancan1
Post by Gmancan1 »
Makes since tho ee do like a portable hotspot its
Like handy for caravans and places you csn get landline
O2 tried to sell me one with 40 gb but sure could use that in a day 🤣😂
Never thought about draining phone 🤣
SmokeyTheBandit
Well the bed is nearly finished. Turned out great, very sturdy.
The bed is made of 3 pieces. The larger part can be hinged up and mounted to the wall.
The other part can be installed with a few bolts and stored in the attic. I also made a handle so its easy to carry arround.
Post by stu_b »
looking great
at that height can probably double as a table top too ;)
Really innovative build this, I like how you’ve managed to do these mods while keeping it compliant with local laws. You’ve done great work so far.
SmokeyTheBandit
Thanks @ the swan friend
@stu_b
Yes its rather high but the bed simply comes out to much if i had mounted it against the wheel arch. Now its using space again that it'd rather normally don't really use. and i can also walk in the middle.
I'm now lacquering the entire bed which is quite time consuming ..... but worth it :lol:
I also have some more additional idea's i want to incorporate in the counter.
Also now have a sliding door with an opening window. But as its against the law to have a window that can be opened on the road. I made a bracket and removed the handle from the window. Which should make it legal but still usable when i unscrew a few bolts.
Ill also finish the wifi repeater install this weekend. And explain and show what it will do :D
SmokeyTheBandit
Here is a picture of the bed folded up.
Legs can be removed as well if needed.Image
SmokeyTheBandit
Wifi module mount made with magnets.
Can be easily mounted and installed.
Post by stu_b »
I am interested to learn how you made this WIFI Module and how well it works and what it achieves :)
SmokeyTheBandit
Will let you know Stu!
Now working on some technical upgrades for the caddy.
Bought the following:
New GTD Turbo
Massive aftermarket intercooler
Custom exhaust
Darkside Developments downpipe
Just did a full service with everything (cambelt kit + new oilpump + oil pump belt).
All the filters are renewed as welll
Post by stu_b »
Sounds like your getting deep into it
