Hi. Can anyone recommend a code reader for my 2007 caddy 2.0 sdi. I turn the key and the van fires up but cuts out. I then have the car symbol and glow plug light flashing. I started it this morning and reversed it into my drive to wash it fine.
The blow plug light works as normal and no other problems that I know if.
Code reader
Re: Code reader
Sorted the running problem. I got a new key shell from Amazon and hadn’t thought about the immobiliser chip. Put the old shell back on and everything is fine. Still looking for code reader advice though. Thanks
Re: Code reader
Obdeleven will work nicely, keep the dongle in your van and run the app on your mobile.
Re: Code reader
I use VCDS, i have obdeleven too but VCDS ia better for me, also VCP or vag commander is good enough.
