Page 1 of 2
BG Bike Van
Posted: Mon Jan 03, 2022 6:13 pm
by timangus
Here are my plans:
Head Unit with CarPlay/Android Auto
☑ Reversing Camera
☑ Reading Light with Microphone
CarPlay/Android Auto USB Socket
☑ Auto Headlight Switch
☑ Touran Centre Console
MFSW
Spacewalker Module for Cruise Control
Rear Door Handle
☐ Some Way to Hold Bikes Upright
☐ Pressure Washer
☐ Air Compressor
☐ Insulation/Carpet Lining
☐ Bodywork/Paint
☐ Fix Dent in Nearside Door Runner
☐ Fix Dent in Nearside Wing
☐ Fill Antenna Holes in Roof
☐ Remove Auxilliary Lock on Rear Doors
☐ Fill Various Scratches
☐ Remap
Pictures more or less straight after I bought it:
Re: BG Bike Van
by timangus
Re: BG Bike Van
by timangus
Installed an interior rear door handle:
Re: BG Bike Van
Posted: Mon Jan 03, 2022 6:14 pm
by timangus
I've posted about this elsewhere on the forum, but I made an
adapter so I could fit the CarPlay/AA socket in place of the 3.5mm jack socket in the Touran centre console storage box:
Bit of sanding and painting on the print to make it look less like a 3D print
Re: BG Bike Van
Posted: Mon Jan 03, 2022 6:15 pm
by timangus
Re: BG Bike Van
by timangus
To get the cruise control working in my PQ van I needed to get
Spacewalker's module. It's a pretty fiddly soldering job, but all doable.
Got it all installed and working except for the horn, which would peep whenever I turned the CC on or off. This was hilarious for about 30 seconds. Bit of investigation and the wiring needed some adjustment.
Starts like this:
This purple thingy needs to come out:
Remove the grey wire from the yellow plug:
Remove the grey and blue wire from the black plug (and discard the grey wire completely):
Plug the blue wire in place of the grey wire in the yellow plug:
Should look like this:
Et voila, working horn.
Re: BG Bike Van
Posted: Tue Jan 04, 2022 6:16 pm
by gpaolo2kn
great way to transport the bike!
the steering wheel is T6 of which year? thank you
Re: BG Bike Van
Posted: Tue Jan 04, 2022 7:13 pm
by timangus
Couldn't tell you exactly as I got it from a breaker site unseen, but the part number is 7E0 419 091 M.
Re: BG Bike Van
Posted: Wed Jan 05, 2022 9:17 am
by sewi
Great work there on the wheel. As for composition Media vs Discover Media you're probably right but I tend to appreciate the nav on mine as a backup and it shows direction on the cluster which is a nice touch
Re: BG Bike Van
Posted: Thu Jan 06, 2022 7:12 pm
by Jonhall
Looking good, nice work!
I’ve also been having the bike dilemma since getting my Caddy late last year. Settled on a setup from Blok, comprising a rail that fits across the rear threshold tie-down points and fork mounts.
Works great with MTBs, but drop bar road/gravel bikes are a challenge as the handlebars/levers extend beyond the front axle… might need to make my own ultra-offset plates to solve that
Re: BG Bike Van
Posted: Thu Jan 06, 2022 10:12 pm
by timangus
Yep, that's an option I've come across before, but not for me I think. The main reason I went with a maxi was so I could fit a couple of bikes in the back without taking the wheels off, because I'm lazy
. My current thinking is to weld up some kind of jig to hold the rear wheel(s), screwed to the floor near the bulkhead. Like one of the things you park your bike in outside the café at Glentress if you've ever been (I'm sure they're doubtless at other places too). There is some off the shelf plywood contraption that does the same thing, can't remember what it's called at the moment, but it seemed a bit bulky and overbuilt.
Your solution looks good though, very neat
Re: BG Bike Van
Posted: Fri Jan 07, 2022 8:19 am
by Jonhall
I know what you mean, would be good to see what you come up with!
I’ve seen something like that ‘off the shelf’ too, but I also thought it looked a bit overkill (and expensive!).
Re: BG Bike Van
Posted: Sun Feb 13, 2022 5:56 pm
by timangus
My headunit and camera install went off without a hitch in the main, but there was one little niggle that bothered me, that being that when reversing the PDC overlay on the camera was disabled, and couldn't be enabled. I did a bit of googling and found anecdotal evidence that this was because the software level of the PDC module (2K0 919 475/PARKHILFE 4K H03 0004) was too old to communicate correctly with the headunit. So I took a gamble and bought a replacement PDC module, and whatdyaknow, now it works:
It's a 7E0 919 475 T, from a T6 I believe, PARKHILFE 4K H03 0212. Only downside is that now my instrument cluster is complaining 12671232 - Function Restricted due to Missing Message(s), I can only assume that the parking module's software is so much newer to the extent it is sending some message(s) that the instrument cluster doesn't understand. It doesn't clear and I don't see any obvious coding options in the cluster that would make it go away, but any ideas are welcome. It's not really a big deal anyway as it doesn't seem to affect anything other than making my autoscan untidy. Perhaps what I need is a Parkhilfe 4K H03, but with a software level somewhere greater than 0004, but less than 0212
. I'll keep an eye out and if I can get such a module for cheap I might experiment further.
Code: Select all
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 2K0 920 966 C HW: 2K0 920 966 C
Component: KOMBI H03 0905
Serial number: 00000000000000
Coding: 480800
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 3038ECAB4AADA5CB171-8064
1 Fault Found:
U1111 00 [009] - -
[Steuergerät für Einparkhilfe: keine Kommunikation]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 176
Mileage: 59857 km
Date: 2022.02.09
Time: 14:50:10
Re: BG Bike Van
Posted: Fri May 27, 2022 1:27 pm
by timangus
Small update on the above. I picked up
another parking module, a 5N0 919 475 D (PARKHILFE 4K H03 0045) out of a Touran or a Tiguan. With this one I get the sensors overlay as before, but my instrument cluster isn't complaining about missing messages any more. Win.
Code: Select all
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5N0 919 475 D HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0045
Revision: -------- Serial number: 32961220000425
Coding: 308001
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_EPHVA14VW3680000 001005
ROD: EV_EPHVA14VW3680000.rod
VCID: 3A2CCE839CD16F9BC1B-806E
No fault code found.
Coding: 480800
VCID: 3038ECAB4AADA5CB7FF-8064
Re: BG Bike Van
Posted: Tue Jun 07, 2022 3:37 pm
by sim
what kind of bikestands are you using?
BR
