Yeah, cheers bud.
I actually found an AF which is midline, SW0070 and compatible with the steering angle sensor for just £9 inc post on eBay. It’ll be here Tuesday. Don’t mind taking a chance for less than a tenner.
Picking up a steering wheel tonight from a member, advice req’d
- Exuptoy
Re: Picking up a steering wheel tonight from a member, advice req’d
You won't want to fit a highline module unless you've got a MFSW, most don't support the horn for the non-MF airbag harness.
- Exuptoy
Cheers for the heads up Doc. I bought the midline AF one. Should be here by Tuesday then my mate is gonna code the cruise as I can’t find my VCDS k-can lead. I’ll still need these clocks coded at some point though, so we’ll have to sort something.
