Flat bottom steering wheel
Hollis182
Re: Flat bottom steering wheel
Post by Hollis182 »
I’m trying to find a thick, flat bottom steering wheel for my 2007 Caddy as mine is thin and worn down to the carcass. I can’t quite seem to find the right one
Mine now is so worn and old I wanted to upgrade it for comfort more than anything any help will be appreciated
Hi, welcome to the forum.
There are several flat bottom steering wheels which will fit your caddy, maybe looking for a thick one is limiting your options. Do you have an example of a wheel you would class as thick flat bottomed?
Exuptoy
Post by Exuptoy »
I got this one from a member in here for £150
No issues with fit, came from an 18 plate Caddy maxi
Hollis182
Post by Hollis182 »
That’s the exact thing I am looking for, going to have to hunt around for one now
Ambrose2KN
Post by Ambrose2KN »
Although loads of ones can fit isnt there ones with a correct airbag for certain models? I've got a 2010 ex-BG maxi and looking for a flat wheel but I want the airbag to work..any help and direction would be great!
Ex-BG Caddy daily
Rastamouse
Post by Rastamouse »
I need a steering wheel (when I can afford it ha ha ) 😂 are they hard to do ?
