PD130 Conversion
- Azz03
Re: PD130 Conversion
[mention]Andy4Shaw [/mention] all my engine work was done by a guy local to me who’s a vw specialist he converts these engines in his sleep he knows that much about them. My set up now is running 200bhp with the standard turbo so once I change to hybrid I could potentially push a lot more as he’s told me.
As for the shafts he’s mate bolt straight on again the guy who done my engine said the mk5 golf gti ones are a lot more rated for the torque and power also they sit a lot better if the van is lowered.
Here’s my cooler
Here’s my cooler
- Azz03
[mention]Andy4Shaw [/mention] as for a new brake set up I’m not sure read lots of reviews about people chasing to r32 brakes front and rear and not really noticing the difference so I’m either going for something like s3 or the brembo 18z’s all depends on costs I guess
Yeah that makes sense re the driveshafts, and I obviously want to lower it!!
What other mods have you done to get 200bhp? I bet the van goes like a scalded cat in comparison to before?
Reason: removed quote
- Azz03
PD130 Conversion
[mention]Andy4Shaw [/mention] it’s got pd150 injectors egr delete full straight through stainless exhaust hard pipe kit s3 intercooler and I used the golf turbo for now until I go hybrid. The guy I know who does these conversions can get 200bhp safely out of a 1.6tdi
The engine I had in it before was at around 185/190bhp so it’s not much of a difference still moves pretty quick and it’s a gti killer haha
Hi there I've got a BKD shaft fitted drivers side perfectly but Passengers side the bolt holes werent big enough , did you use mk5 gti ? and where did you get your cooler and hard pipes from ? Dan
- Azz03
[mention]Dt33 [/mention] I’ve got mk5 gti ones to go on as I’m still on touran 6 speed ones.
Do gti ones fit?
- Azz03
[mention]Dt33 [/mention] yes mate as the caddy’s are pretty much based on mk5 golf as I’m running mk5 gti front shocks a lot of vw parts are compatible with the vans
Hi, okay ideal, yeah just doing my build at present have fitted passat hubs, lower arms along with MK5 platform H&R springs and Koni shocks , fitted a BKD shaft drivers side but the shaft I got for the passengers side was wrong (think they sent a 5 speed instead of a 6 speed) wanted to check GTI ones worked as well
- Azz03
[mention]Dt33 [/mention] that’s also on my list to change the lower arms to Passat ones. Did you go for b6 ones? Also then poly bush everything front and back. Yes mate as far as I’m aware pretty anything mk5/6 will fit the vans very versatile vans lol
Have you got to 300bhp yet? Could you tell us how it drives?Matt090494 wrote: ↑Sun Oct 18, 2020 6:59 pm ...I have recently converted my '07 Caddy to a BLT PD130 retaining the PD105 turbo and Injectors.
...aiming for 300hp
Reason: edited the quote
Hi there what hard pipe kit is this as it looks a good fit?
Dan
Dan
- Azz03
[mention]Dt33 [/mention] it’s from a company called creation motorsport based in the West Midlands or you can get the kit off eBay.
