SWB MK3 1.9TDi Build thread
The_Evil
Engine size/power: 2.0 CNG (107bhp)
Re: SWB MK3 1.9TDi Build thread
Post by The_Evil »
@neil278 I have almost everything in this list, exception for the looms and relay for the compressor, part of the wiring from the Climatronic to the car control unit, a couple of temp sensors and the sunlight sensor.
Ah, is the double fan mandatory for the cooling radiator?
neil278
Post by neil278 »
I haven’t fitted the double rad fan. On looking at cars being broken on eBay I see both fitted to cars with ac so decided not to
The_Evil
Post by The_Evil »
Yeah, I think I read here around that it's optional, but probably a good idea for the summer italian temperatures! ;-)
The_Evil
Post by The_Evil »
Neil, please don't hate me with my tedious questions...
How did you connect the Climatic to the Can bus?
neil278
Post by neil278 »
Can bus is the orange/brown and orange/green
Mancwebby
Post by Mancwebby »
Outstanding where best place for head unit upgrade
neil278
Post by neil278 »
Cheers ;) good old eBay, just avoid the RCD360 it looks the same but it’s just a copy
Lomax
Post by Lomax »
Hi Neil,
I hope you can help. I came across this thread following watching a YouTube vid where you are mentioned.
I have a caddy with touran door cards and the central locking isn’t working. I went to follow the guide on what pins to move around and found out that this had already been tampered with and I currently don’t have a starting point. I think the white wires are numbered. Would you know what white wire goes where on each drivers / passenger side?
Jamk
Post by Jamk »
neil278 wrote: Thu Aug 27, 2020 6:08 pm Move pin 11 to 12 - pin 13 to 16 (this wire not present on passenger side) - pin 7 to 6 - pin 15 to 7 and pin 16 to 13. The red and yellow wire from position 12 now needs to go into 18.
Door modules were 5K0 959 792 on the passenger side and 5K0 956 793 on the drivers side
Now everything is working as it should :D just need to get the door cards cleaned up and fitted, then upload some pictures but it’s now pissing it down :?
This post saved my day, you legend 👍🏻
(I have a 2011 caddy with 2007 door modules but was just what I needed to get the re-pinning done) central locking/mirrors and windows now sorted
cyderspace
Post by cyderspace »
Just want to say - a massive thanks to you for this re-pinning info. Without this I would have been stuffed. Amazing!
In my case I used it to change from the old 1K0 959 793 door module on my 2013 Caddy which had the white wiring numbered from factory - to the new 5K0 595 793 KLO with motor I installed.
neil278
Post by neil278 »
Didn’t realise I had some replies on this thread 8)
Glad the info has helped some fellow caddy owners out
akerstrom
Post by akerstrom »
Do you remember the part number you used to get the steeringwheel buttons to work? I have the same wheel installed and I would love to get the buttons working :)
neil278
Post by neil278 »
Yer it’s 1k0953549CH
To use the buttons on the right hand side you need a multifunction display, as that’s what it controls
akerstrom
Post by akerstrom »
Thanks!
I have the mfd from factory so all good there.
Great looking build :D
szybkilopez15
Post by szybkilopez15 »
Anyone could let me know what wire colours should go to each pin? previous owner repinned mine wrong and I have got to sort it out
thanks for help
