Reflex Silver Caddy (66)
Re: Reflex Silver Caddy (66)
Would be good if a good top box could be printed.
Plenty in here would buy one!
- ToiletTFSI
@Dav02
If you sand the top smooth, you could either heat the surface equally and press a texturised mould onto it to give the look. Or equally a very light skin of plastic filler on the the top after it’s been keyed and then press the texturised mould.
Think there is a kit that you can make moulds from existing surfaces - the pass side where the airbag or prob be a large enough area to do this.
Reason: removed quote
- Dav02
Interesting, I’ll look into it once we get the final build sorted.
- Dav02
1st prototype of top box fill in.
Printed in 3 parts. Lets us place in 1 piece at a time to see where clips line up.
After a few cuts to test fit I’ve got it to go in. Will need to make some amendments to the design to get the fit correct.
- Giddy
That looks promising, well done.
Brilliant start
- ToiletTFSI
very nice
- Simon_B
Hi mate
Can you remember what glue you used for your door card trims?
Cheers.
Cheers.
Mk4 Highline 2.0 TDI.
- Dav02
I plastic welded them back in using a soldering iron. There should be enough from the door cards themselves to re glue back in place once the separate parts are removed.
However for any tabs that didn’t, I had some ABS plastic rods to add extra support.
Glue for the cloth was just the standard trim adhesive
- Simon_B
Cool,
I've just got hold of some mk7 door cards and removed the handles.
Also purchased some plastic welding rods too.
May go with faux suede as I've used it before and was reasonably close to alcantara.
Thanks.
Thanks.
- Dav02
Version 2 of dash top cover.
Still quite a few amendments to be made. So hopefully next one shouldn’t be far away.
- Simon_B
- Jabba
Anyone know if this will work for a mk5 caddy had looking to do this to mineDav02 wrote: ↑Fri Apr 29, 2022 12:30 pm Onto the next one.
Footwell lighting.
Purchased from Stan the Man.
Red ambient lighting while driving, white light when stopped/doors open etc.
The new lights and loom
Original wiring loom out
Wiring in
Finished (after some VCDS coding)
Sorry for the photo spam
Would love this footwell kit for my mk 3 maxi. If who ever is putting the kits together please pm me. I cant pm yet
- Dav02
Have you requested access via this thread
https://www.caddy2k.com/forum/viewtopic.php?t=31039
Sorry Jabba I've no idea on the mk5 model
