Headlight Wiring Diagram
Afield23
Post by Afield23 » Wed Jan 17, 2018 11:29 am
Can anybody please tell me which wires are for the DRL's so I can fit the resistors? Image
Afield23
Re: Headlight Wiring Diagram
Post by Afield23 » Wed Jan 17, 2018 12:10 pm
From reading other people's posts and risk of fire, if I mounted the resistors to the metal subframe(?) with some heatsink grease would this be adequate?
Post by Doc » Wed Jan 17, 2018 12:26 pm
Rather than risk fire with a resistor, why not have the bulb error coded out.
Afield23
Post by Afield23 » Wed Jan 17, 2018 12:27 pm
I much prefer this idea but I need to find someone with the professional kit.....
Post by Doc » Wed Jan 17, 2018 12:30 pm
There are a few people with the necessary tools on this forum, where are you located?
Afield23
Post by Afield23 » Wed Jan 17, 2018 12:33 pm
Essex but I'll happily take a drive to whoever may be closest?
BB13
Post by BB13 » Wed Jan 17, 2018 1:29 pm
heres a pin out for a headlight, its the same pin on both sides.
Afield23
Post by Afield23 » Wed Jan 17, 2018 1:55 pm
BB13 wrote:heres a pin out for a headlight, its the same pin on both sides.
Does that mean it's 10 and 4 on the connector block? Not sure how to interpret that drawing and the quality isn't good enough to zoom in on.
BB13
Post by BB13 » Wed Jan 17, 2018 2:22 pm
Hi
yea pin 4 is DLR and pin 10 is side light. what part of Essex you in ?
Afield23
Post by Afield23 » Wed Jan 17, 2018 2:24 pm
Brentwood. You near?
BB13
Post by BB13 » Wed Jan 17, 2018 4:00 pm
church Langley,
Afield23
Post by Afield23 » Wed Jan 17, 2018 4:19 pm
Not far then. Have you got the ability to code out the bulb warning with vag con pro?
BB13
Post by BB13 » Wed Jan 17, 2018 11:51 pm
I do have a genuine micro can lead (vdcs) never looked at cancelling out that before though.
Afield23
Post by Afield23 » Thu Jan 18, 2018 12:01 am
It's not possible with VCDS unfortunately. Got it sorted now though, has to be done using vagcan pro. Cheers for the help though!
smunter1
Post by smunter1 » Thu Jan 18, 2018 7:58 pm
Sorry to be so ignorant fellas, I'm new to this. (there are going to be a few posts about electrics from me ha)
Is the reason you're looking to fir resistors because of the LEDs?
I've seen you can get LEDs that don't bring up the errors, do these not work? Is the only way to get rid of the errors to either fir resistors or get them coded out
