Central locking install?
I bought a 2007 Caddy , with no aircon , no electric windows and no central locking.
how easy would it be to install electric windows and central locking?
Would it be better to buy OEM from a scrapyard or after market?
And anyone in South africa know where to get it?
Also how easy would it be to install front fog/spot lights on a panel van bumper?
2007 1.9 TDI Caddy Panel Van (Pre Facelift)
1994 Golf Mk1 16V
1989 Caddy mk1 2L 8v
1974 Beetle , named Bumblebee (my first car and my show car) Slammed to eart
1994 Golf Mk1 16V
Re: Central locking install?
Bump??
Anyone have some advice on central locking?
1994 Golf Mk1 16V
1994 Golf Mk1 16V
Do you have central locking (all door lock/unlock when you use the key in drivers door) but just no remote control?
It is likely your central convenience module (CCM) will support remote central locking (RCL) and a simple pairing of the correct remote should allow you to use this.
Can you get the part number from you CCM? It's located behind the glove box.
Hi Thank you for the response
The Caddy didnt come out with central locking, I would like to fit either OEM or after market Central locking.
1994 Golf Mk1 16V
1994 Golf Mk1 16V
So you have to lock and unlock each door manually, one at a time? Thats very poor for a car produced in 2007.
I suspect you have a bigger problem if this is the case, the doors should all lock when you lock the drivers door with the key in the lock barrel and unlock just the same.
Yes, I have to lock all the doors manually, which is a big inconvenience... the 2007 caddy was advertised without central locking,
If it should lock when I turn the key on the door, what could be the problem?
And any idea of how hard it can be to install central locking, even if it manual central locking with turning the key in the door slot?
1994 Golf Mk1 16V
1994 Golf Mk1 16V
Best first port of call would be a full VCDS diagnostics scan to determine if the need to manually lock each door if by fault or design. Maybe the locks are capable of operating centrally but the function is disabled in some control module. Maybe there was a extreme poverty spec that was available in SA and some wiring was left out to fit into a price point.
Cool i will see if i can run diagnostics, i hope that can be the problem, i really want central locking
1994 Golf Mk1 16V
1994 Golf Mk1 16V
Sorry to wake up an old post.
Did you get central locking installed in your caddy?
I am also from SA and have a 2007 2.0SDI with no central locking and electric windows. I do have aircon tho
Hi, i did not get central locking installed... but i bought TDI and sold the petrol one.. and the tdi had central locking, but it doesnt control the sliding door or the rear doors... i still want a solution to that.
1994 Golf Mk1 16V
1994 Golf Mk1 16V
- Eric001
did you guys get it sorted I'm also in south africa and have a 1.9tdi and want central locking
