How to wire up A5 seats?
B3035418
Post by B3035418 » Wed Apr 01, 2015 7:53 pm
I have just fitted A5 seats in my caddy there part electric heated and electric lumbar support there are 4 plugs red, black, green and yellow
any advice on wiring these up would be very much appreciated or know of any looms I can buy to fit
thank you
Icegeezer
Re: How to wire up A5 seats?
Post by Icegeezer » Sat Apr 04, 2015 6:15 pm
Really interested in this too...
Any progress at all??
stan-the-man
Post by stan-the-man » Sat Apr 04, 2015 6:59 pm
For Audi seats to work OEM style you need:
Vw heated seat module
Heater panel with heated seats control (either standard, climatic or climatronic depending on your current equipment)
Custom wiring loom
If the seats are electric or partially electric I recommend getting thermal fuses too, for lumbar standard 15A blade fuse will do.
From the colors of plugs, my bet is green is heating, red is electric control, black occupancy sensor and yellow airbag.
I can dig out wiring diagram for ye lads if you want. It would help if you roughly knew what year was the Audi.
Icegeezer
Post by Icegeezer » Sat Apr 04, 2015 7:22 pm
Thanks dude,
I'm heading down now to try and wore them so that would be amazing
My seats are from a 2010 S line 3 doors
Red, black and yellow plug
Full electric, no memory with heating,
There is a switch on back of drivers seat too?
Oh and a light underneath...
Thanks dude
stan-the-man
Post by stan-the-man » Sat Apr 04, 2015 7:35 pm
Without seeing it the button could be easy entry.
Icegeezer
Post by Icegeezer » Sat Apr 04, 2015 8:14 pm
And luck on diagram or description to get this working, only worried about movment atm
stan-the-man
Post by stan-the-man » Sat Apr 04, 2015 8:58 pm
If the pin 4 in the red connector is red/black 2.5mm2 and pin 5 brown 2.5mm2 then this is your power for movement...
stan-the-man
Post by stan-the-man » Sat Apr 04, 2015 9:03 pm
It's important you use proper gauge wiring as putting skinny ass ones under such load might cause them to over heat and melt. Use fuses too. Just a heads up
B3035418
Post by B3035418 » Sat Apr 04, 2015 10:11 pm
stan-the-man wrote:For Audi seats to work OEM style you need:
Custom wiring loom
Spot on Stan thanks my seats are from a 2011 or 2012 sline Audi A5
stan-the-man
Post by stan-the-man » Sat Apr 04, 2015 10:18 pm
Are both your seats the same regarding electric control? I presume only backrest and lumbar are electric and movement is manual?
What year is your caddy? I'll post up the wiring diagram so you can work out whats what etc.
Icegeezer
Post by Icegeezer » Sat Apr 04, 2015 10:21 pm
Mine are fully electric - got all that working now,.
Is there any way to wore heated seats Into a non heated loom, he through a relay and a simple on or off??
B3035418
Post by B3035418 » Sat Apr 04, 2015 10:32 pm
stan-the-man wrote:Are both your seats the same regarding electric control? I presume only backrest and lumbar are electric and movement is manual?
Yeah backrest and lumbar is electric my caddy is 2011 facelift
stan-the-man
Post by stan-the-man » Sat Apr 04, 2015 10:35 pm
This is OEM setup for caddy FL
I'll check the A5...
EDIT: can't find info on partially adjusted seats in A5Image.
B3035418
Post by B3035418 » Sat Apr 04, 2015 10:40 pm
The looms that you do what's included and if I got a set from you what extra would I need to get fully working thanks
stan-the-man
Post by stan-the-man » Sat Apr 04, 2015 10:49 pm
The loom will have everything ready to go (fuses, plugs etc.) you will just need to get the heater module and heater panel.
The loom will be ready for mostly straight forward plug and play application. You'll just need guts to strip few trim panels to fit it. You would also just have to follow my connection list and get someone with vcds to enable heated seats in BCM.
