Knocking through the clutch?
- KarWerx
Ive only had my van a fortnight, its a 57 plate Tdi.
When i press my clutch very lightly, just enough until the biting point i can feel a slight knocking through my clutch pedal. Is this normal?
It does this whilst in motion as you just find the biting point.
- PrePavGav
Re: Knocking through the clutch?
Doesn't happen on my 56 plate, mate. Release bearing?
- Grizzle
happens on mine personally i'm just leaving my clutch till it goes BANG and then i will get a new one.
1.9 TDI PD, Custom Code remap 156bhp & 239lbft , rear tints, 16" Golf GT Alloys, VW Mudflaps, H&R Springs, Cruise Control, Koni Sport Dampers, GT Badge, MK5 Golf GTI brakes all round.
- KarWerx
It's only slight but it wasn't there when I bought it. I've got a vw warranty. Should I use it or wait
- PrePavGav
If you've got warranty then use it. No reason not to. Its not 'normal' for it to knock.
s31teg
- KarWerx
just a slight vibration thro the pedal. Its as i change gear. I guess it could be the clutch release bearing.
Ive read that this part isnt covered under the VW warranty for cars, so im guessing that its the same on the commercial warranty.
Whats the costs involved here, is it an easy job? Is it worth putting in a new clutch?
- PrePavGav
Yeah, you are right come to think of it. Not covered. Done a couple of clutches in the past but never on a caddy. Quite long jobs requiring 2 people unless you've got a fully kitted out workshop. You have to take the transmission off which will be heavy! You need a ramp or a pit too.
- Grizzle
The part is like 30-40 but its the hassle of doing it without proper ramp and kit.
- VW-PADDY-TDI
One man job as long as you have at minimun an engine crane or some kind of rope winch from a roof perlin and asuming you dont mind gettin dirty
- KarWerx
This is an unexpected cost as i have just bought the van, however im not too bothered as i planned to uprate the clutch at some point in preperation for a remap.
I want to keep costs to a minimum. What bits do i need to change while im at it.
- Liam
mine is knocking and a vibration thru pedal and its supposedly down to the flywhhel ! il know for definite on sunday as its goin to garage to get clutch kit done friday-saturday and il collect it sunday when i get back from sligo !
Build thread here
Build thread here
- KarWerx
^^ Liam..
If its the flywheel, i presumed thats covered by my VW warranty. Maybe i should go to a VW Van centre to enquire..
- Liam
yeah get them to tell u whats wrong and if its gonna cost u to repair u decide who u want to do the work
Build thread here
Build thread here
- KarWerx
more hassle. Im getting a quote from my friend to change the clutch to an uprated one. Anyone recommend a kit?
