I have and would advise it, using gps all the time seems like a painAUSCaddyMaxiLife wrote: ↑Sun Jul 18, 2021 11:41 pm Do you bother with keeping the rolling diameters the same or just use GPS for a speedo?
The Caddy Alloys Thread
RY_VW
Re: The Caddy Alloys Thread
More to follow
More to follow
RY_VW
@Ade16 use https://www.willtheyfit.com/ to see how alloys will sit compared to your existing set up, for 18 and a width of 8j people tend to like a et45 off set, anywhere around that I'm sure you'dbe safe(do double check though), I've got 7.5j and et51 on mine and only stick out an extra 5/6 if I remember correctly so to me its perfect
and for your search I'd go for anything under the vag group for what size you want and just see what offsets are. I ended up knowing what models have which offsets and all sorts by the time id finished
More to follow
More to follow
veedubgub
Anyone know what wheels these are?
Sent from my E5823 using Tapatalk
RY_VW
@veedubgub
VW Seattle
VW Seattle
More to follow
More to follow
veedubgub
veedubgub
Got one more (sorry)
Anyone able to put a name to these?
RY_VW
@veedubgub I dont know the style name but theyre vw eos alloys
More to follow
More to follow
veedubgub
Thanks again @RY_VW
Possibly Adelaides as i got a few results back with that name when searching for eos wheels
Russ74
Fitted these Audi B7 DTM wheels 8J ET 43 with 225/40/18 Tyres
- Exuptoy
Only read as far as P20 and so far haven’t seen my rims in here. They’re genuine VW EOS/Passat ET47 7.5x18 Solitudes. Very similar to the 19” R32 rims but the spoke detail is slightly different.
Needs lowering now.
Mine were powder coated in Iodine colour(
) which is basically a metallic anthracite colour.
Needs lowering now.
Carolthecaddy
How do I figure out what wheels will fit?
RY_VW
@Carolthecaddy use https://www.willtheyfit.com/ for defence with offsets and widths, centre bore is 57.1 and stud pattern is 5x112. I think the most favoured setup is 8j and around et 42 but theres lots of setups people have got on if you have a read through this thread you'll see. I've gone with 7.5j width and et 51 and think it's perfect
do you want aftermarket or vw group? If you go vw group most golf,touran,passat,leon,Octavia and the likes will go on
More to follow
More to follow
Stricky
Anyone have any idea of what steels these are and what size they have been banded to?Mastakillahkungfu wrote:Only got one photo of banded steels.
- JimBob3000
Does anyone have any examples of either Mk7 GTI clubsports or Mk6 GTI Edition 35's on a black caddy?
- Giddy
@Stricky
Custom banded steel wheels. You can chose pretty much any size you want 15-19"
