Time to start a new build. Ex BG maxi. Hereford.
Re: Time to start a new build. Ex BG maxi. Hereford.
Thanks for the laugh :lol:
Nicklouse
Post by Nicklouse »
FishermansFriend wrote: ↑Thu Jul 13, 2023 9:57 pm Thanks for the laugh :lol:
Got the translation now.
Nicklouse
Post by Nicklouse »
A bit of fabrication today as drilling holes in the bumper cross beam was not happening last weekend.
Also sorting out the wiring for the fog/driving lamps.
Tomorrow new harness for the “Elk spotters” and connect up the rest.
Nicklouse
Post by Nicklouse »
All back together.
Just need to wire them now.
Nicklouse
Post by Nicklouse »
Time to start on the inside.
Picked up 2 lengths of 20mm hollow section. But before getting started with that it’s time for other things.
Closer panel tomorrow.
Nicklouse
Post by Nicklouse »
Next delivery fitted.
Air vent will be changed over the weekend when I will also be making a start on the interior.
Nicklouse
Post by Nicklouse »
Whirligig air vent gone new solar one fitted.
Then this evening was mainly spent with this lot.
Those that have done similar will know why the spark plug socket is on there.
Post by stu_b »
that solar whirlibirdi looks nice
the low profile makes it less noticeable
did it slot straight into your old hole or did you have to make some adjustments ?
what did you use the rivnuts on ?
Nicklouse
Post by Nicklouse »
The hole needed enlarging.
Rivnuts and cabinet bolts to hold the panels on.
Come in a selection of lengths and have a nice big head.
Post by stu_b »
hopefully it wasn't too much or a ball ache
have to say, the end result looks good
you've either got to fill the hole with metal. prim and paint or get done at a shop
or, replace with a similar product
the later looks shmick !!!
no wires required as it's solar ;)
so the rivnuts went into the back of the panel and you've put "big theaded" bolts in from the front - hex head (hard to see on my device) ??
they look pretty flat, do u have any pics of the nuts by themselves ?
what size, M6 ?
Nicklouse
Post by Nicklouse »
stu_b wrote: ↑Mon Aug 14, 2023 10:11 am hopefully it wasn't too much or a ball ache
so the rivnuts went into the back of the panel and you've put "big headed" bolts in from the front - hex head (hard to see on my device) ??
what size, M6 ?
Yes M6.
The holes for the VW plastic fixings needs enlarging as many don’t have much room behind using a socket etc as a stop works well.
Some explanation pics.
Post by stu_b »
ahhh yes that looks good
the flat head bolts are a nice touch, sleek
the eyebolt is nice too, what do u plan to use that for ?
Nicklouse
Post by Nicklouse »
stu_b wrote: ↑Tue Aug 15, 2023 11:56 am ahhh yes that looks good
They are just useful.
Post by stu_b »
yes I agree
wasn't sure if you had grand plans for them :)
Nicklouse
Post by Nicklouse »
As the headliner joiner was not present. A strip of 3mm alloy. Rivnuts and cabinet bolts. Will coming off after it has set in shape and will get covered in vinyl .
Like the speaker pod.
