Aftermarket virtual dash display
Dav02
Re: Aftermarket virtual dash display
Post by Dav02 »
Like the look of these dashboards. If no issues may have to upgrade
2016 Caddy Highline. 2.0 TDi 102ps (ReMapped to 180)
Build Thread
416
Post by 416 »
This is an interesting thread, if you had said "virtual instrument cluster" my initial thoughts would be no way! Especially where it was never an option. (OEM+ is my preferred modifications)
However, looking through this thread and the examples, these do look to be of a reasonable quality!
foolhardyViper
Post by foolhardyViper »
gazza31112 wrote: ↑Fri Apr 25, 2025 8:29 am Hi mate,
The add blue works, not 100% sure yet if I get a reminder, but definitely has an add blue range.
It does have Bluetooth but iv never actually connected it as I use my head unit for music and android auto.
It has screen mirroring which works through WiFi but as I have a Google pixel which won't allow anything to be mirrored that's not Google... It doesn't work.
But was showed at TMG that it works perfectly with an Iphone, and my Mrs Samsung connected straight away.
It's been in since the end of January, no issues at all with it resetting or turning off.
The distance radar does bring up a symbol, similar to the one on the standard cluster but it does flash which is a tiny bit annoying, the crash warning will do its usual beep but not show anything.
You can personalize the colour of the van on screen and ambient colours, there's other VW models to scroll through, can change from a MK3 to MK4
It has a weird little race mode which can time your 0-60s (it's a bit of a gimmick tbh)
There's definitely a few things which tell you it's not OEM.... But overall I'm really happy with it
Btw have you got an Instagram? I had a few questions regarding your modified xenon's..
I'll ping you over a pm on here but I see your not on here very often. Cheers Image
@gazza31112 how are you finding the dash a couple of months on? Reading TMG's posts, he states its a version they have worked on to fit better, but I think its Just the AE version? Did you just pay for delivery and fit it yourself, how did it compare to previous models it fitting, and slotting in?
TMG say they ship with all required tools and instruction video, assume its still a case of swapping motherboard and chips where required over?
Also how are things like AdBlue alerts, and Service Intervals handled, do they still display?
Cheers.
Hi mate, so far so good with it. Had no issues at all.
I was going up to the lake District anyway so I just stopped by tmg to have it installed by them. Did look pretty easy if you know what your doing, just swapping a few things over.
Adblue and service intervals are in the menu but I haven't had an alert come up, so assume (not certain) because haven't left my adblue to get that low, that you have to go into the menu to check the levels.
Sent from my Pixel 9 Pro XL using Tapatalk
foolhardyViper
Thanks, thats great to know! Its definitely on my list. I have watched a couple of vids of the install required for those units, I think if patient and careful its not the most difficult. Appreciate the reply! Cheers!
carl.g
Post by carl.g »
Hey all, jumping on this thread. Would anyone know whether I can upgrade to the virtual cockpit directly from a startline instrument cluster, or would I first need to swap over to highline clocks and then to Virtual for all the stuff to work?
corrigan42
Post by corrigan42 »
I just swapped my 2019 Startline dash to one, and it works fine! Do you have the multi-function display?
carl.g
Post by carl.g »
I suppose my cluster is not MFD, it must be the most basic version. No trip information or visuals when a door is open except for a bulb. I suppose I would need to upgrade to a highline cluster first. Not sure which part numbers I should go for though, for 2016 mk4. I've read that 2K0920975E is a highline cluster, not sure if 2K0920976E is also highline? What part number was your old MFD if I may ask?
Thanks for your help!
Alex mc
Post by Alex mc »
You don’t happen to have a copy of the instructions for the TMG cluster do you mines arrived but these were not in the box
Fat Eric
Post by Fat Eric »
I’m sure I have watched a TMG video of the installation, possibly their website or YouTube.
Alex mc
Post by Alex mc »
I have watched this however doesn’t cover all clocks . There is an assumption that all clocks are the same once opened up . My MK4 cluster doesn’t have the small clip to split the LCD display from the mother board.. I’m no wondering if I need to now buy a higher level cluster . I don’t have a MFSW and was advised to buy the remote with the clocks which I did and this come loose in the box again no instructions how to set it up with the clocks . It’s all good I’ll phone them tomorrow.
Illowminati
Post by Illowminati »
If everything works, it really enhances the car and makes it look much younger, especially since it's more attractive.
dialer
Post by dialer »
That's absolutely cool.
I've seen a u-tube video outlining the entire installation.
Very tempting.
Roan’s Caddy
Post by Roan’s Caddy »
Very cool.
r.mcdonnell61
Post by r.mcdonnell61 »
Class, DTETV on youtube goes through the install which may be of use to some: https://www.youtube.com/watch?v=9vg4TfuNbgk&t=1741s
2016 VW Caddy 2.0l TDI 5 Speed Manual
