caddy tent/awning
horace01
Re: caddy tent/awning
Post by horace01 »
These are very popular here in Australia. Bit of a PITA if you want to pop to the shops or drive away anywhere.
Sent from my HTC 2PS6200 using Tapatalk
caddywupz
Post by caddywupz »
Still can't seem to find a decent reasonably priced barn door awning/cover.
Quite annoying...
Anyone found anything new out there?
Photographer & Caddy Conversion-er
Instagram Photos: neil_irwin
Instagram Caddy: caddywupz
Ricco
Post by Ricco »
Nice, enjoy!
hermitsrest
Post by hermitsrest »
branwell wrote: ↑Fri Jul 28, 2017 3:03 pm Image7 by John MacDonald, on Flickr
Image20170722_192155[1] by John MacDonald, on Flickr
I was just looking at this ARB awning recently as a potential for my Caddy Maxi Life (available from campervanculture.com). I already have a poptop roof so probably wouldn't be able to do the roof rack install you have. Is that to achieve the 2500mm height of the cube tent inside? Would love to see some inside shots and how easily you access the sliding door.
hermitsrest
branwell
Post by branwell »
Unfortunately it is packed away just now so i am unable to share any photos. Basically when it is up, the awning room gives you a living floor space of 2.4 x 2.4 m, which for us is plenty big enough to fit two comfy Oztent beds in with a bit of space to spare.
Aligning the sliding door with the awning room door is possible. The way i set it up this time gave us about 60cm gap. I think if i moved the awning part along a bit we would have had a better alignment of door openings. First time we used it it, it was a bit of trial and error, but in general it works well and gives a great living space.
schu8888
Post by schu8888 »
Anyone got a pop up sort of awning? I remember back from my t4 days some used a decathlon one?
tangoed-caddy
Post by tangoed-caddy »
Haven't got a pop up but this is my inflatable one, goes up nearly as fast as a pop up and seriously stable in winds ImageImageImage
Sent from my SM-A300FU using Tapatalk
DM01
Post by DM01 »
Great photos...
CaddyAndy
Post by CaddyAndy »
That's a great size, can I ask what make it is tangoed caddy?
tangoed-caddy
CaddyAndy wrote:That's a great size, can I ask what make it is tangoed caddy?
Not sure on make but you can buy it from Decathlon and costs £215 including the pump that is Image
CaddyAndy
Post by CaddyAndy »
Good stuff, thanks.
What's the seal like to the van?
tangoed-caddy
CaddyAndy wrote:Good stuff, thanks.
Very good takes few attempts to find best fitting but once correct then keeps wind and rain out very very well
CaddyAndy
Post by CaddyAndy »
How do you keep it attached then?
tangoed-caddy
CaddyAndy wrote:How do you keep it attached then?
Well main tent part obviously stays pegged in permanently then one side has an elasticated wall that goes over the roof of the van and along the side of the van to keep a tight fit, and that has guy lines holding it down on other side of the van
dizzee stuff
Post by dizzee stuff »
Think I walked past your van parked up on shell island ?
