Danny1221
Post by Danny1221 »
Did some lights today and bonnet work ImageImageImage
Sent from my SM-S938B using Tapatalk
STP
Post by STP »
@Danny1221
Did you use vag can pro to code out the light warning for the reverse light? Can you share the process in vag can pro if so?
I fitted LED DRLs at the front and love them, but still have the orange warning for left hand sidelight check. I'd like to code that out, I have VCP but never used it before and don't want to screw up my module coding. It can't be done with VCDS or Obdeleven, which I am familiar with.
Jude99
Post by Jude99 »
Today I've fitted a matt black bumper protector to my Mk5 Maxi Life's bumper as experience tells me that bikes and camping gear will soon leave their mark!
Also today (along with fitting the bumper protector) I've been using my new trim removal tools to remove the trim inside the driver side rear around the toolkit / emergency tyre repair kit.
It's a scary job removing clips for the first time as you don't know which bit to pull or how much force to use. I've only broken one clip. Unfortunately it's not replaceable as it's part of the horizontal strip that goes at the bottom of the large storage pocket. The superglue is now setting!
What I'm looking for, behind the wall lining, is somewhere to secure a kitchen unit. I'm also weighing up sound deadening and insulation options. I've gained some confidence today. Yes, I know I'm going to make my lovely new car look awful for a while but you can't make an omelette without breaking eggs!
Mk5 Caddy Maxi Life 2.0 TDI DSG 122 PS
Jude99
Post by Jude99 »
Today I worked out how to remove the plastic surrounds from the seat anchors in the back of my Mk 5 Maxi Life. Push the pin down and out of the clip, remove the (now loose) clip, then lever up the plastic surround. Unfortunately, the surrounds of the front anchor points of the 2nd row seats are different and I couldn't get them up. I might not need to remove them, though, as I think I can pull the carpet out backwards.
I also failed to refit the side panel in the load space. I can't work out how the metal spring clips work. Time to search youtube again!
caddy25
Post by caddy25 »
grabbed some mk5 jetta seats outta work anyone ever see them with drawers underneath ive never seen a set like these before
i must say there very clean seats from a 2008 jetta 1.6 petrol and a hell of a lot comfier than the standard caddy seats fitted them into the van this evening along with the touran seat frames that have there own storage so ive two sets of storage under both seats now
look identical to these
''cross threaded is nature's loctite''
lukescaddy
Post by lukescaddy »
gazza31112 wrote: Wed Aug 27, 2025 5:13 pm Attempted a doorcard retrim....Image
This looks unreal! have you got a link to the material you used? and anymore progress pics?
Thanks mate! Yeah I'm pleased with it.
Iv now done all the removable panels in the back and headliner in the fabric aswel.
I brought it from transporter hq months ago. But unfortunately this nice soft suede one is now out of stock..... Everywhere. A few suppliers do the same pattern but it's a slightly rougher fabric, still nice but not as soft to the touch as the suede one.
I'm hoping the suede one will come back in stock so I can redo the back bits in it.
If you search for RS embossed hex suede (any other that transporter hq will be the slightly rougher version)
Try RC fabrics or Harrison trim
I'll get some pics up of the finished interior later on my build thread
son of eevil
Post by son of eevil »
Admittedly, this is over the last 2 afternoons so, we can call this "one day" technically?
Dropped left and right struts, calipers, rotors, removed ball joints tie rod ends and sway bar end links.
Dropped right side lower control arm. I tried to drop the left side LCA but the gearbox is in the way and the forward bolt won't come out. I tried getting a jack under the box and lifting it up to make space but didn't quite work.
So, I think I'm going to have to drop the sub frame to replace it.
STP
Post by STP »
son of eevil wrote: Fri Sep 05, 2025 10:51 am Admittedly, this is over the last 2 afternoons so, we can call this "one day" technically?
I just did both of my control arms and didn't have any issues? Did them on the driveway using the standard jack. They have to come out from behind the hub and go back in that way or they put up a real fight. Mind you I have the later ones without the aluminium ends, all steel. Front bolt comes out towards the front bumper and can't be tightened until the van is resting on its wheels again. 80nm I think from memory.
VWMxVan
Post by VWMxVan »
Bought a set of xenons and VCDS so looking forward to fitting them and coding . Expensive but always loved xenons since my MK6 Golf R days Image
Sent from my SM-S928B using Tapatalk
MK4 caddy pure grey, OZ ultraleggera, 6 speed box 140 ecu.
KTM 250 EXCF Six Days
MK3 Clio RS200 ( Meglio) 340bhp track orientated.
Flog_TSC
Post by Flog_TSC »
Hit the starter with a hammer as got stuck while food shopping hahahah
son of eevil
STP wrote: Fri Sep 05, 2025 1:43 pm I just did both of my control arms and didn't have any issues? Did them on the driveway using the standard jack. They have to come out from behind the hub and go back in that way or they put up a real fight. Mind you I have the later ones without the aluminium ends, all steel. Front bolt comes out towards the front bumper and can't be tightened until the van is resting on its wheels again. 80nm I think from memory.
Could be dependant on the gearbox motor combination? On the 1.9 BLS with the DQ250 it was absolutely silly I'm about 50mm (2") from being able to remove the bolt.
STP
Post by STP »
Could be mate, you could drive a bus past the bolts on the 1.6 with a 5 speed. Never seen the bls underneath so just wondering why they made it so difficult on yours.
I had to jack the engine to do the alternator clutch pulley and stretch belt (that was a laugh...not) as the frame rail blocks you getting the torx bit into the alternator shaft.
I got a little tiny bottle jack from Halfrauds and it was perfect for this, sat on 3 planks of wood to reach the sump and a other small plank on top to protect the alloy sump, that may be what you need bud. The engine lifted about 2" easily without any complaints from the mounts. The jack was about £15. Little tiny orange thing apparently rated at 1.5 tonnes. Very handy.
(The reason it needed sat on wood to reach the sump was it was already jacked up on the drivers side with the standard jack and had the wheel and arch liner out to reach the bottom pulley)
son of eevil
STP wrote: Sat Sep 06, 2025 8:10 am Could be mate, you could drive a bus past the bolts on the 1.6 with a 5 speed. Never seen the bls underneath so just wondering why they made it so difficult on yours.
I'm not too cut up about it to be honest. I have to replace the DMF and I was tossing up taking it to a mechanic to do it, but if I'm dropping the sub frame and my LCA's are out I may as well just do the job and safe some $$$.
I've ordered some parts and special tools for the job so over the next few weeks I'll drop the gearbox, replace the DMF and rear main seal. Then I have brand new mounts bushings, tie rod ends, ball joints, shocks, struts to put back in.
For your viewing pleasure, the left side LCA bolt and it's alignment with the DQ250.
STP
Post by STP »
That looks ridiculous, why the hell they designed it that way defies belief. I feel your pain mate.
