Problem coding cruise control with OBD11
Gingeruk
Re: Problem coding cruise control with OBD11
Post by Gingeruk »
Mine accepts the coding but when i activate the cruise i get the cruise symbol and the exclamation mark and then when i scan it i see the stored fault for cruise set signal. It is very frustrating but will get it sorted..........................eventually :D
STP
Post by STP »
Looks like you have to recode the steering wheel module to the options you have, after adding cruise to the engine ECU, here's a video on the golf 5 which must be the same I expect.
https://youtu.be/ZeXO-35da04?si=JANtA0-NHLE4Fzy1
Best Caddy & Transporter upgrade content on YouTube: DTETV
Larryd
Post by Larryd »
Ginger uk, perform a full scan in obdeleven and upload the text to here so we can see how they differ.
Scotscad
Post by Scotscad »
Hi,did this issue ever get resolved?? Im having similar problems trying to code cc but i have the stalk and not the steering wheel buttons.
STP
Post by STP »
Try the video I posted above. Steering control module coding, as I'd said before to you mate, sounds like your problem.
