The white caddy
PJD
Re: The white caddy
What of the Life trims for the dash. On the van (not Life version) they look moulded to the dash itself and therefore not removable. However I don't think VW would have gone to the trouble to have two different dash panels manufactured so there must be a way to cut them back.
- Joeyboy13
Re: The white caddy
Decided to change the alloys to the mk8 estoril alloys and got my hands on a pair of scirocco pod clocks so decided to order the flip up dash box which was only an option for the LHD market so spent some time sanding and cutting to get the clocks and and pocket to fit nicely,also got an engine cover and battery box to tidy up the engine bay and got rid of the plastic washer bottle cap and replaced it with a rubber one. Installed the TRC front lip and maxton side skirts and rear diffuser and fit a reverse camera
- Joeyboy13
Re: The white caddy
Quick lick of paint in the rear to tidy it up a bit for now, I plan on sound deadening it and carpet lining it down the line
- Joeyboy13
Re: The white caddy
Finally got myself some seats for the van , picked these gtd seats up and fitted on touran bases and got a discover media mib2 head unit with dual sim to support my reverse camera and have factory sat nav ,unit is also unlocked for apple car play and android which is a great upgrade from standard unit. Was messing around with some coding and changed the start up screen to R logo and got my dash trim and centre dash trim painted gloss black and got them fitted to button everything up , finally the interior is starting to take shape lol
- Lister79
Re: The white caddy
Looking good, very tidy.
- Joeyboy13
Re: The white caddy
Thanks you
Reason: Quote of previous post removed
- Padrino
Re: The white caddy
Impressive work so far. I really like what you doing to your Caddy
Keep them pictures coming
Orgoglioso di essere Italiano
- Joeyboy13
Re: The white caddy
Thank you matePadrino wrote:Impressive work so far. I really like what you doing to your Caddy
- Joeyboy13
Re: The white caddy
Thank you mateLister79 wrote:Looking good, very tidy.
- Joeyboy13
Re: The white caddy
A little tidy up in the rear on 2 minds wether to install a power inverter or not
CaddyMountain
Re: The white caddy
Looks very clean!
joshouttram
Re: The white caddy
Some unbelievable work you've done there
Are the footwell lights part of a kit or taken from another VW?
- Joeyboy13
Re: The white caddy
Thanks mate they are genuine caddy footwell lightsjoshouttram wrote:Some unbelievable work you've done there
- Joeyboy13
Re: The white caddy
Thanks mateCaddyMountain wrote:Looks very clean!
- Joeyboy13
Re: The white caddy
Swapped out the clear lens side indicators for some tinted led ones
