Page 842 of 1073
Posted: Thu Dec 17, 2020 3:24 pm
by R8umar
Decided to do the VW badge gloss black and wrap the backing the same colour as the van
Can anyone tell me what I've done to my tailights. They don't light up in the E pattern anymore. This is a genuine mk4 but I have been messing around with some coding so I'm not sure what I have done
Posted: Thu Dec 17, 2020 3:53 pm
by lokoli
Winter wheels fitted today
BBS SR 17x7.5J ET45 with 235/45/17 tires
Posted: Thu Dec 17, 2020 6:48 pm
by caddychris2002
R8umar wrote: ↑Thu Dec 17, 2020 3:24 pm
Can anyone tell me what I've done to my taillights. They don't light up in the E pattern anymore. This is a genuine mk4 but I have been messing around with some coding so I'm not sure what I have done
Did you do an Auto-Scan and did you save it before you changed the coding? if so revert back to the old code by going into the log and copy and paste it into the new coding box found in the coding section of the correct module if that makes sense? then start again
Posted: Thu Dec 17, 2020 7:38 pm
by Gwiz
First mod to my van couldn’t resist as it came off a 2019 seat and was a bargain at £25 squids thanks silverlake
Posted: Thu Dec 17, 2020 10:49 pm
by deanopolini
Gave it a well needed wash !
Posted: Fri Dec 18, 2020 10:24 am
by DeanWhit
Deanopolini, that's a lovely van.
Posted: Fri Dec 18, 2020 10:26 am
by the swan fiend
I have to agree with you there Dean
Posted: Fri Dec 18, 2020 10:28 am
by Treads
Tidy
Posted: Fri Dec 18, 2020 12:56 pm
by anoneamus
Strange, AFAIK there's no way to do this via coding. Needs a EEPROM edit via VCP..
Posted: Fri Dec 18, 2020 1:06 pm
by RallyeS2
Today cluster replace, Caddy 2K 2005
Old:
"New":
Posted: Fri Dec 18, 2020 1:58 pm
by R8umar
I did it using obdeleven. It had a history mode so I should have my original coding there I'll give that a go. Thanks
Posted: Fri Dec 18, 2020 2:24 pm
by R8umar
@anonymous hi, I did try revert back to original but it didn't fix anything. I'm sure where it says new software version I may have tapped that and uploaded a newer version. Could that be the problem?
Posted: Fri Dec 18, 2020 3:23 pm
by anoneamus
R8umar wrote: ↑Fri Dec 18, 2020 2:24 pm
Possibly. I don't know anything about whatever app you're using, where it gets software updates from or what applying them does to your vehicle. You need to edit the BCM configuration EEPROM and write it back to BCM. AFAIK the only software that can do that is VAGCANPro.
Here is a post I made on the edits that would need to be done:
viewtopic.php?f=6&t=40406
Posted: Sun Dec 20, 2020 10:11 am
by rbu_tuninq
I 've fitted the low level sensor for screen wash bottle... i just have to try pin 17 on cluster and coding.
Posted: Sun Dec 20, 2020 6:55 pm
by caddychris2002
@R8umarwhereareyoulocated mate, I have VCP sure I can help you out.
