Page 812 of 1073
Posted: Wed Sep 30, 2020 11:00 pm
by Papa Bear
Removable bulkhead?
Posted: Thu Oct 01, 2020 6:57 am
by Caddy46
What mm plywood are people using for the door and boot covers? Got some 3mm backing alacantara to cover them?
Posted: Thu Oct 01, 2020 1:05 pm
by Papa Bear
Audi internal door handle lights finished and coded
Dash Caddy wired in :D
Will take better photos tonight.
Posted: Thu Oct 01, 2020 1:06 pm
by pete3dmunds
Doc wrote:Hmmm, I'm intrigued...
Mounting something behind the upper B pillar trim or deleting the bulkhead?
It's for a coat hanger ImageImageImage
I'm fitting the caddy life plastics and have a hole in the plastics where the factory coat hanger goes
Sent from my Pixel 2 using Tapatalk
Posted: Thu Oct 01, 2020 7:39 pm
by Papa Bear
Well pleased with Audi handle lights. Come on with headlights. Need to see if I can get coming home etc lights working.
Dash Caddy looks brighter in photo than in real life. It’s linked to foot lights so goes on with door opening. Not on all the time.
Posted: Thu Oct 01, 2020 7:42 pm
by ViralEye
I thought about giving the door handle light things a go as I had a full Audi for card set bit sold it all in the end... Need to find some more and give this a go
Posted: Thu Oct 01, 2020 8:03 pm
by Craig Cheatham
Blue lights look superb, great work Pappa!
by Papa Bear
Got mine from scrappy, got all the bits rather than having to buy them separately from Audi at £55
Posted: Thu Oct 01, 2020 8:10 pm
by Katiecaddy
@pete3dmunds
I’ve been looking for those exact parts for ours for a while so that I can fit our coat hangers,
I don’t suppose you have the part number fo4 them?
Katie
Posted: Thu Oct 01, 2020 8:39 pm
by Beaker2135
Swapped out the standard spare wheel for a 16” one, the wider tyre made the carrier a bit to tight for comfort so I dropped a 14mm nut over the bolts to act as a spacer
Posted: Thu Oct 01, 2020 10:21 pm
by Vdub-si
Fitted black roof rails and a new high level brake light to my 09 caddy
Posted: Thu Oct 01, 2020 10:33 pm
by Tum-yeto
Stripped the rest of the ply and OEM boards, removed headliner and bulkhead and gave it a good clean.
Posted: Fri Oct 02, 2020 5:56 am
by Ryzar1
Hey guys just fitted and wired new fog lights today fleebay specials they came with a loom and relay I’ve seen quite a few posts on here about installation I read somewhere that the wire for the switch has to be put into the number 10 pin on the back of the rotary switch ( provided you have the switch that has front and rear fog light options) much frustration found out that it’s the number 7 pin not number 10Image
Posted: Fri Oct 02, 2020 8:23 am
by Ryzar1
Trying to remove the tow bar and put the original crash bar back on......I’m stumped I’ve removed every bolt I can see and the bloody won’t budge any suggestions Image
by Ryzar1
