Sebhell
Re: Caddy Maxi - daily and camper build
Post by Sebhell »
Stumbled upon your thread looking at doing similar work with my newly acquired Caddy Maxi 2.0 TDI 4M.
Trying to navigate all the different opinions on sound treatment and insulation is a nightmare when you're a little bit too used to falling down the rabbit hole of research before getting started!
Feels a little bit better following a fellow Swede knowing you might encounter similar environments although I live a fair few hours up north between Åre and Östersund.
A question regarding the cargo flooring. How do you fasten the flooring on top of the sound and insulation treatment? Glue I'd assume is out of the picture as it would only adhere to the insulation foam. Did you screw or bolt it down on top of the treatment?
Love your build and attention to detail, looking forward to the continuation of the thread!
Sparktan
Post by Sparktan »
Was this a straight swap from the rcd310 , everything works as with the old unit apart from bluetooth music control which endeed will be a bonus ! Thank you in advance
