- Oldgregg
[mention]ViralEye [/mention] very nice. Thought that bloke in the background was hanging out the van, good optical illusion going on
- Papa Bear
Nice looking samurai too
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- Papa Bear
Taken the rear headlining out, fixing the wires up etc, going to dye the headlining too.
Any recommendations for cleaning the headlining first?
Seen @doc did this a couple of years ago.
Got 5 litres of autobrite to use, going to make a right mess
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- DeanWhit
Coilovers ordered and booked in to be fitted next week. Just trying to decide on alloys now but I keep flip flopping between 3 sets. Just can't decide.
fishcatdog
what sets are tou looking at?
I'm loking for some aswell ,only decided on 19" and grey ones ,so many to choose !!!
- R8umar
This is the current situation of my van. Recently brought it damaged, have stripped back and now on hold waiting for my parts to arrive. Intake manifold needs changing. Soon as I've got everything running perfect I will then start with the panels.
Sent from my SM-G988B using Tapatalk
- r1lea
I’ve got my old pair of mk4 headlights mate if any good for you, I’ve Upgraded to bi xenons
- R8umar
Appreciate that mate, but I've just brought a pair from ebay. I purchased the black edition headlight with drl, non xenon version. I wanted xenon but not in my budget right now.
You should get £150 for the pair easy.
- Matias
Today fit a first lining lugage panel (must a little repair, we havent in czech longer than 1,5m. My panel have 2m) and repair coroded window switch. Now clean and working fine. And change rear wiper from T5. Very nice. More better than ori. :-)
VW Caddy Maxi Life 180 HP
- DeanWhit
@Fishcatdog
I've now narrowed it down to 2 sets. A riviera set and a veemann set. The veemann wheels aren't usually my type but I think they would look smart. The riviera's are my safe option
- RKDesigns
Built an rs3 rearbumper and sell this one.hef355 wrote:![]()
geo.stronach
@R8umar
Looking forward to the repair/mods was it copart by chance?
Reason: Removed unnecessary quote, replaced with @ tag
- R8umar
Hi, thanks will keep you posted. Yes from copart. 2.0tdi caddy highline
- rich181
Finally got my GTD seats in on touran bases. So much more comfortable than the originals and a lot more adjustable than I expected. Was expecting to be sitting a bit higher than I normally prefer but could lower them down quite a bit.
Thanks to tommyzoom for the airbag loom.
- Mattyh606
@rich181 dont the gtd seats fit on the normal caddy bases ?
Sent from my SM-N976B using Tapatalk
