Page 720 of 1073
Posted: Tue Apr 21, 2020 1:17 pm
by Vwjack88
My tiny little job for the day on the van. Popped these little beauties in. Looks better
Posted: Tue Apr 21, 2020 2:28 pm
by tonyhill
^^^^ If it wasn't for the little triangle window, you'd swear the white van was a mk4
Posted: Tue Apr 21, 2020 5:17 pm
by Humphreys2006
I took all my ply lining out ready to put sound deadening in and found loads of 10mm holes in the van floor
. No wondwring whats best to cover them all with
Posted: Tue Apr 21, 2020 10:31 pm
by Stedlocks
Continued prepping the caps ...
In my fantastic spray booth, I laid down the primer man...
tomorrow, I base coat and lacquer....! Hopefully, while they’re drying, whip the door cards off (he says, all casual like) and put the new bases on.... plus other stuff!
Posted: Wed Apr 22, 2020 6:47 am
by Mattyh606
Humphreys2006 wrote:I took all my ply lining out ready to put sound deadening in and found loads of 10mm holes in the van floor
Foil tape and then your sound deadening pal
Sent from my SM-N976B using Tapatalk
Posted: Wed Apr 22, 2020 10:46 am
by Humphreys2006
Mattyh606 wrote:Foil tape and then your sound deadening pal
Thanks mattyh606
Posted: Wed Apr 22, 2020 8:25 pm
by ajjoyce
Fitted reverse camera. New knobs for heater controls and wired up a wireless charge to sit in the cubby below the ashtray
Posted: Wed Apr 22, 2020 8:39 pm
by Sean1066
Posted: Wed Apr 22, 2020 8:51 pm
by james400
Started to flush my rear doors one door at a time no rush lol will carry on 2moz
Posted: Wed Apr 22, 2020 8:54 pm
by Barrington
@ajjoyce did you have to put a relay on to make the reverse camera work clearly I'm having a nightmare with mine
Posted: Wed Apr 22, 2020 9:01 pm
by ajjoyce
No mate I taped into the rear wiper. It is currently permanently live with ignition. I will be looking at taping into the reverse for the switch signal but that’s a job for tomorrow
Posted: Wed Apr 22, 2020 9:08 pm
by Barrington
Ahh I don't have a rear wiper
Posted: Wed Apr 22, 2020 9:59 pm
by Ant bliss
Started to paint my calipers yellow,now got even more reason to get some spax coilovers
Posted: Thu Apr 23, 2020 12:13 am
by Stedlocks
One flipping wing mirrors...!
It looks good, but you need to be a gynaecologist to get the radio aerial through the hole!!
Posted: Thu Apr 23, 2020 7:52 am
by the swan fiend
@Barrington. What is it exactly that you’re struggling with mate? I’ve done a rear cam install and I may be able to help.
@ Pat, nice work mate. They look good
