Time to start a new build. Ex BG maxi. Hereford.
- Nicklouse
Re: Time to start a new build. Ex BG maxi. Hereford.
As I did not take pics of the suspension work here is something else.
- Nicklouse
Well I am getting through the parts to change trying to chase down this vibration.
The ride is better with OE struts on. And the top mount noise has been eliminated.
There is still no play to be felt in the front wheel bearings so it’s time to change the drive shafts.
Ordered from J&R should be here for the weekend.
Everyone says you can’t feel a worn rack through the steering wheel as a vibration……. Soon it will be the only thing that won’t have been changed.
Ps yes I have swapped wheels.
theoldseacaptain
I had a steering shudder / vibration that I chased for a while as it was only really noticeable when running fast on the continent. I was at the point of replacing the driveshafts when I thought about what had been changed since my last vibration free trip and the penny dropped about the brakes. Replaced the 5-month old discs and pads again and it was perfect.
Turned out the disc that had been on the n/s/f was bad.
- Nicklouse
Well,
I think I know where I went wrong I did not look at my tyres last weekend.
The underlying problem was the top mounts that were giving the vibration. That had been there with both sets of wheels. Then a bit of wear to the tyres before getting the tracking done.
When the tracking was done they mentioned that the camber was high on one side but that was most likely the strut top mount as it could be heard.
Well today during lunch I was just wanting to check the thread size on the ball joints so I had to put full lock on. Mmm that’s a knackred tyre. Put the winter wheels back on the front and went for a quick spin on the motorway. Vibration has gone. Will be running like this till I can get new tyres.
- Nicklouse
Had the old spare sand blasted and I then slapped some paint on.
Cheapest suitably load rated tyre on.
Back under the van. Wonder when I might see it again.
- Nicklouse
The two rear window areas done, one side 4 way stretch and a charge net
And the other side where the sink will be vinyl.
Now to sort the work tops out.
Well maybe next month or the next.
- Nicklouse
- Nicklouse
Top mount. Did not have a suitable ring spanner. Had tightened them before fitting but wanted to check.
- Nicklouse
Going to do something.
- Nicklouse
I bet the old rose petal was twitching hard when you were drilling n cutting into the door
You have got an awesome result
- Nicklouse
Needs another coat and a bit on the tops of the wings.
Then the defector will go back on.
- Nicklouse
Got to go as it just lets too much water in!
Larryd
As a new ex-BG owner, I have throughly enjoyed seeing this build.
