Another bike van build
Flog_TSC
Re: Another bike van build
Post by Flog_TSC »
Looking great
Flog_TSC
Post by Flog_TSC »
Q
uins
Post by uins »
Looks great mate very tidy jobs
Transitionpilot
Post by Transitionpilot »
Aaand we are back! Went a bit quiet for a while as couldn't really see the point in logging in (access restrictions blablablah) - In between work/real life and making the most of this unreal summer to get out on my bike, I have been slowly ticking off jobs and will start catching up with posting the progress!
uins wrote: Thu Feb 26, 2026 8:22 pm Looks great mate very tidy jobs
Flog_TSC wrote: Sat Nov 29, 2025 8:17 pm Looking great
Cheers very much peeps!
Transitionpilot
So, on to one of the main jobs that everyone has to do - and I don't think it's anywhere near as much fun as it looks when you watch some else do it on YT! the carpeting :roll: If you're reading through this before doing a van for the first time - DO IT SLOWLY! - It will take longer than you think
, If I remember right I went with Anthracite colour because I felt that full black colour would probably show up dirt etc a lot more.
Taped up all the holes with 2 layers of foil tape
Removed the bulkhead and taped some plastic dust sheet up to stop the glue overspray from getting into the front
Getting stuck in, a reet mess!
These little clamps from BQ were super useful to hold the big pieces in place and not get stuck to itself
Transitionpilot
Eventually getting through it, You can see a few wrinkles on the wheel arch, these will be covered up by the box though. I made the mistake of sticking the carpet into the recessed parts first which isn't the best way, it's better to hang the carpet and then stick down all the large/main parts and then use the stretch to work it into the small or tight parts....
Finally done, had to work out a few random wrinkles and make a cut in the corner of the barn door pillar/wheelarch section but happy with that in the end.
kobat79
Post by kobat79 »
Nice work mate. It looks great. I'm about to tackle this myself so it's great to get some tips!
And thanks for writing it all up and posting. That's not easy given the issues with the forum at the moment.
Transitionpilot
kobat79 wrote: Fri Jul 17, 2026 12:19 pm Nice work mate. It looks great. I'm about to tackle this myself so it's great to get some tips!
No probs! If you haven't bought the carpet yet have a look for Shieldautocare or VLT on ebay as they are much better prices than everyone else for the same stuff, and they do most colours in 2 different thicknesses/weights.
Transitionpilot
Next up was the roof panel, as I like to do the things the awkward/hard way I wanted to make the roof ply as 1 piece. Got a 5mm sheet and laid out the 2 original bits and the plastic strip together and traced around them, simple enough. Put some rivnuts in the original clip holes and then tried to hold up a 7ft long floppy sheet of ply with one hand while using the other hand to get the bolt into a hole I couldn't see was a bit of a faff, came up with a wway to hold the sheet up and free both hands though!
Transitionpilot
After a test fit, it got carpeted and the lights put in. I made a perfect wiring harness for the lights, nicely taped and with superseal connectors but found that it wouldn't pass through the gap behind the roof ribs so I had to cut the connectors off and use single bullet connectors for each wire, somewhere along the way I've connected them wrong and the lights don't switch to the permanent feed - after the faff to put the roof in, I'll have to wait until I'm in the right mood before taking that out again lol! Looks ok though, 2x Golf R interior lights and it's super bright inside.
