kobat79
Post by kobat79 »
Now that my leaks are sorted I finally got around to stripping all of the rust from the floor pan behind the passenger seat. I was surprised by how deep the pitting was in some places. I stripped all visible rust using clean and strip discs and wire brushes then treated it all with kurust, before painting in two layers of rust inhibiting primer. I'll topcoat in a couple of layers of LL7E Flannel Grey this week now that the evenings are bright again.
Before
After
Mattfirth
Post by Mattfirth »
Not done it yet but picking up some Saab 9000 seats today, not sure if/how they will fit but i remember them being soooo comfy when i sat in one as a kid.
Velour too which is my preferred fabric.
Oh and £20 for a full set helped me take the gamble😁
Ill update with pics of the success or just me crying.
Update: after a couple of quiet nights at work, they did fit after a bit of fettling.
Can't work out how to post pics though...
Poffe
Post by Poffe »
Moulded wheel arc panels in polyester resin and fibreglass. Then reupholstered them in the same Alcantara fabric as every other panel. It has never been so close to be “finished” before.
But, starting to think that I might sell it. The 1,6 TDI hasn’t been that reliable as one could hope for. And going for long trips in a car that might break down in the worst possible situations isn’t as relaxing as a vacation should be.
Sent from my Nokia 3310
Poffe
Post by Poffe »
Mattfirth wrote:Not done it yet but picking up some Saab 9000 seats today, not sure if/how they will fit but i remember them being soooo comfy when i sat in one as a kid.
You need the app Tapatalk to post pics. Please post, I’m very curious on how the Saab seats fit in a Caddy!
Passat w8 light finally fittedImageImageImageImage
Mattfirth
Post by Mattfirth »
Poffe wrote: You need the app Tapatalk to post pics. Please post, I’m very curious on how the Saab seats fit in a Caddy!
Been busy, then struggled with the app but got thereImage
The Saab seats are a touch wider than the Caddy's, ended up using one rear captive nut in the caddy bases and drilling/spreader plating the others.
They are comfy and I like how old Saab seats look, but they do sit low on the caddy bases. I believe the Touran bases are higher so I'll try source a pair of them.
I'm super frugal,(some might say tightImage) and as the seats were £20 I'm holding out for a cheap pair, could be a long wait..Image
Grill light 2.0, started as a Mk8 GTi grill Image
Nice
Finally got the doorcards back, fully alcantara with matching stitch pattern insert, all plastic welded back together.
Got the ambient lighting in and the flake plastic trims all in. Passenger side tomorrow! ImageImageImageImageImage
Crazy, mad, genius.
Nice
kobat79
Post by kobat79 »
I got the steering wheel control module swapped out so my mk5 GTi MFSW now works properly, including the flappy paddles :D I also finally had cruise control fitted which is mega. So nice on the motorway!
