Roni - TFSI Maxi
Transitionpilot
Re: Roni - TFSI Maxi
Post by Transitionpilot »
The next tip to the mountains will have to have a detour through some derestricted autobahn I reckon!
VeeDub
Post by VeeDub »
Winter mode has been engaged.
Van has been lifted a little with a Darkside rear shackle kit and the coilovers would up a little. It’s been raised around 20mm and has made a surprising difference to the comfort
Also fitted some 18” Speedlines with Goodyear Winter Tyres which I bought a couple of months ago
The shackle kit had two holes to centre the rear axle in the arch. I have a problem where having the rear wheel centred in the arch is causing the tyre to rub on the arch linings. Any tips on what’s gone wrong here?
Baldspeed Racing
Post by Baldspeed Racing »
If the wheels are sat too far forward in the arches you can get centralizing plates which would make the wheels sit more central
@baldspeed on Insta
