Starlight Blue Caddy Life - Mk4 2K SA - WAV + Stealth Camper for One.
Re: Starlight Blue Caddy Life - Mk4 2K SA - WAV + Stealth Camper for One.
Plus...
Finally got around to doing an info video for my Fiamma Low Loader bike carrier conversion.
Not great, but hopefully helpful.
https://youtu.be/KFf8wIakwhY?feature=shared
Yay !
Got a new HDPE board to mount my cooker burner on.
Chose a nice Grey Granite board to sort of match the rest of the fittings.
When it arrived I was a little disappointed as it was a bit scratched and had obvious shiny production tool marks :(
Luckily - A quick rub down with a grey Scotchbrite pad and it looks much better
Half way ...
Finished - Faces and edges.
Better check it fits now !
Phew 😅
Looks nicer than the blue one, though functionally no different.
Just got to drill a few holes now ...
Fitted the new Granite Grey board ...
Decided to fully disassemble and mount the burner unit using blind holes instead of through bolts.
Chopped a tiny bit of the end of 4 SS screws so that they don't go straight through the board
Top side (work side) with the four locating points showing (not through holes)
Cooker neatly stowed in the sink
Flipped to cook position
There's enough gas hose to do side by side mode too
