Stuck rear shock bolt advice
Adwano
Post by Adwano »
Working on fitting rear suspension and can’t get the top shock bolt free, unfortunately don’t have access to a ramp so limited with space for longer bars etc and quickly running out of wd40.
Any other ideas to get these free? Or best reassemble and find someone with a ramp to free them?
Not even attempted driver side space looks really lacking to even get a ratchet in with the heat shield
Nicklouse
Re: Stuck rear shock bolt advice
Post by Nicklouse »
WD40 is crap. Get some decent penetrating fluid on them. Either Pluszgas or the special WD40. Leave it on and re apply often then give it a go.
SkyRocket1976
Post by SkyRocket1976 »
Get yourself some Bulldog BDX.
You won't find a better penetrant.
Adwano
Post by Adwano »
Cheers guys, managed to get one side off but will grab some in the morning and give it another go
