Poffe
Post by Poffe »
BagleyCJX wrote: Wed Apr 10, 2024 1:38 pm Colour coding mirrors currently
That is an entirely different type of coding :D
Currently not available in VCDS
thecolourpurple
Post by thecolourpurple »
Sent from my SM-S908B using Tapatalk
BagleyCJX
Post by BagleyCJX »
Poffe wrote: Wed Apr 10, 2024 4:58 pm That is an entirely different type of coding :D
:mrgreen: :mrgreen: :mrgreen:
Scimitar
Post by Scimitar »
Today I started to convert my wheelchair converted maxi life back to a standard 7 seater.. Ramp is off and have plan to rebuild the floor etc back to level.
So far so good
raitis
Post by raitis »
Changed my front passenger side wing which had horrible rust issues because of a previous repair (the arch had been welded from the inside) to a better used one. Now I can't get my front bumper to slot into the bumper bracket :oops:
mac12
Post by mac12 »
Had to top up my coolant, I suspect a small leak somewhere. Not much, just a couple of dL since I last filled before christmas. Any usual culprits I should check? Don't see any puddles anywhere, no white smoke in the exhaust nor residue in the oil so I don't suspect it's the head gasket. Water pump, maybe? I'm at 140km / 86k miles.
bert682
Post by bert682 »
mac12 wrote: Mon Apr 15, 2024 9:55 am Had to top up my coolant, I suspect a small leak somewhere. Not much, just a couple of dL since I last filled before christmas. Any usual culprits I should check? Don't see any puddles anywhere, no white smoke in the exhaust nor residue in the oil so I don't suspect it's the head gasket. Water pump, maybe? I'm at 140km / 86k miles.
Had something very similar, turned out that the plastic inside the oil filter housing had perished. Replaced this and no leaks since.
mac12
Post by mac12 »
bert682 wrote: Mon Apr 15, 2024 10:26 am Had something very similar, turned out that the plastic inside the oil filter housing had perished. Replaced this and no leaks since.
This was an oil leak, no? I'm slowly loosing coolant.
bert682
Post by bert682 »
mac12 wrote: Mon Apr 15, 2024 10:44 am This was an oil leak, no? I'm slowly loosing coolant.
The coolant passes through the filter housing along with oil for the heat exchanger.
Pretty good video here and the signs to confirm.
https://www.youtube.com/watch?v=zA48qKZCVq0&t=169s
mac12
Post by mac12 »
bert682 wrote: Mon Apr 15, 2024 2:52 pm The coolant passes through the filter housing along with oil for the heat exchanger.
Learn something new every day. Thanks for the tip, I'll have a look!
bobmaf
Post by bobmaf »
Fit a new off side drive shaft and spiggot rings
oysroe
Post by oysroe »
Mounted caddy life mirrors. 2 hours of fiddling and only broke 1 clip on sail panel and lost 1 bolt inside the door. Sail panels were a pita to remove. But absolutely worth the work.
Yep.
Looking lovely
Poffe
Post by Poffe »
oysroe wrote: Tue Apr 16, 2024 6:25 pm Mounted caddy life mirrors. 2 hours of fiddling and only broke 1 clip on sail panel and lost 1 bolt inside the door. Sail panels were a pita to remove. But absolutely worth the work.
I can recognize those broken clips and lost bolts situations! Every time I go on and try to improve on the caddy I also tend to brake some clips :)
Nice upgrade! Im looking for Caddy life mirrors as well. Looks so much better!!
