Caddy radio not working
Hi, I have an '08 Caddy 1.9tdi.
I've been slowly sorting things out with it (rear seats, bodywork etc) but I cannot for the life of me get the standard rcd300 radio to work.
I've checked the fuses (under steering wheel, back of radio and engine bay) and all is well, I've even managed to remove the headunit and get it to power up on another caddy.
I'm at a bit of a loss as to what else the cause could be and wondered if anyone else had experienced similar or had any advice on what else I could try to solve this?
As much as I'd planned to upgrade to something newer, as I can't get the original one to work then I'm reluctant to change to anything else. Using it without a radio is starting to get too much now
Many thanks,
Barri
Many thanks,
Barri
Re: Caddy radio not working
Welcome to the forum Barri.
The radio should turn on/off with the ignition, this is done via a CANbus message rather than the old style ignition power wire method.
Check you have positive, negative and CANbus connections on the plug at the back of the radio.
Is there anything plugged in at the back, maybe a hands free harness or something else that's non standard equipment?
Thanks for the reply Doc.
Apologies for the delay, I was away over the weekend.
I'll pull the radio later and see what I can find.
I'll try and get some photos too if I'm unsuccessful in having any luck.
Pretty sure from memory there wasn't anything non standard but I could be wrong.
I'll update with findings.
Barri
Barri
Removed the radio and everything looks to be pretty standard and how I'd expect
Not sure if anyone can see something that I can't that would cause issue.
Hoping the picture links work.
https://postimg.cc/F1HcQqmF
https://postimg.cc/942RggJh
Have you checked that positive, negative and CANbus connections are all good? All looks to be standard factory wiring.
Next step now Doc.
Never really had any radio issues before beyond plug and play with a little fettling.
The fact this didn't work from the time I got the van has made it that bit more of a job but hopefully I'll get somewhere.
Assuming testing can be done with a multimeter to try and pinpoint the issue?
Thank you again for responding
I have a 2005 1.9 tdi - strangely the radio fuses are 'extra' they are on some wires which hang down under / near the interior fuse box. My caddy came like that - I'd assumed that they made a mod during production or something like that
Thanks Peter.
I'll have a look around the fusebox area to see if there's something similar on mine.
I've been to all the usual spots hoping for a quick fix
Those extra fuses are often found on the after market mk3 harness.
Yea, hanging down fuses is not how VW will have left any vehicle from the factory. All factory fuses are in the fuse boxes either in the engine bay or cabin.
The fuse for the radio is in the engine bay.
Did this problem ever get solved I have purchased an after market xtron stero I have connected everything up but no power tried to put the factory stero back in that's not getting no power
