I've just ordered the B8s for £295 delivered.
I'm hoping for a silky smooth ride!
Best rear dampers for lowered Caddy
- Lister79
Re: Best rear dampers for lowered Caddy
Nice one, looking forward to hearing your verdict.
Got Meyle ones on the rear of mine and seems spot on.
2008 PD130 ASZ conversion
Hybrid turbo
Large S3 alloy intercooler
Narco mapped
Hybrid turbo
Narco mapped
Fitted the bilsteins this afternoon.
They're good but not amazing, not a huge improvement over the standard dampers (before they failed). Obviously the standard dampers are not designed for lowered vans so will eventually fail like mine did. The bilsteins are a good option for lowered vans as they are designed for the job and shouldn't fail.
They were not good enough to work with my air bags though, still too bumpy so I've removed the air bags for now. Going to try towing with the bilsteins next weekend to see how they are with the extra weight on the rear. With the standard dampers the rear used to bounce too much while towing.
- Lister79
Try running less pressure in your bags, as too much will make them bounce. I only have 34psi in mine. You may need to make some spacers for under the bags to maintain the same ride height when loaded up.
Mine are only "helper" bags to raise the rear when loaded. To test it today I ran without any pressure in the bags (with the valves open) as I would usually have it when not loaded.
- Lister79
The outcome will still be the same, as what you’re in effect doing with the helper bags is chocking the suspension (presume at mid point, above the axle). Therefore, by running a high pressure in the bags you’re preventing the springs from flexing as they are designed to do. Updated springs or double springs could be a another option to improve the ride.
Such as:
https://www.darksidedevelopments.co.uk/ ... gIHSvD_BwE
Such as:
- caddychris2002
Yep unfortunately following my previous comment mine have done the same. I have Koni on the rear now but looking to go BC all round I think eventuallyDoc wrote:I'd stay clear of the Gaz, I've had my second set fail. They quoted me £190 to refurbish the first set which had the failed within warranty. I foolishly had bought a second set to keep me on the road thinking the failure was a once off.
Sent from my SM-S918B using Tapatalk
www.dav-tec.co.uk
www.facebook.com/davteceng
Autowatch Ghost Installer
Mods:
Mods:
I've had the B8s on for very nearly 18 months now. I'm very happy with them. The ride is good and no issues so far.
Current set needed replacing, unable source rear set for a lowered caddy so used standard banging like hammer on building site. Does anyone have part number for a decent set, having difficulty sorting them outside UK
