I’m with Petrev, can’t see why that would be an issue. The water seems to drain just as well on the side with the rail - but it always fills with bubbles when washing the van
Jon’s camper/MTB conversion
- Jonhall
Re: Jon’s camper/MTB conversion
MkIV (2017) Caddy Maxi Highline 2.0TDi 150bhp DSG
Ok, bubbles. That's really a very serious issue, will absolutely have to think twice about that upgrade..!
Biggest problem seems to find any rails to buy.
2014 Caddy Maxi Life 2.0 TDI - Stealth Camper
I doubt you can get them from Reimo anymore
The 3 versions I linked to are very likely identical or very nearly the same as Reimo
Keder seem to be USA and UK - If you can find a distributor locally it would be good though length is about 2.3m not the 3m of Reimo.
Trivantage also about 2.3m
Bainbridge version is 3m long.
Local supply would no doubt be best - I haven't found a reasonable 3m delivery option from the UK
