Ravenna Blue Caddy Tfsi
Lister79
Re: Ravenna Blue Caddy
Post by Lister79 »
Good to see you putting the effort in to back date the build thread, keep it coming
J_Con
Post by J_Con »
Thanks Chris, thought it was time to start one as the caddys came quite far and not everyone is on Instagram so plenty more to come
J_Con
Post by J_Con »
A before and after of my new front brake set up, also coated in KKD Revolve. These were refurbished by bigg red in Worcester ImageImage
Mpowerkits&coding
Post by Mpowerkits&coding »
Nice build 👌🏽
J_Con
Post by J_Con »
Thank you @Mpowerkits&coding
J_Con
Post by J_Con »
Slip ring changed to a highline for the MFSW
Polo AW wheel fitted with a 3D/Colour clusterImageImageImageImage
golfman
Post by golfman »
That Steering Wheel looks absolutely Mint 8)
gpaolo2kn
Post by gpaolo2kn »
wow! the polo steering wheel is really nice. mounts without modifications?
J_Con
Post by J_Con »
@golfman I suppose it was alright
J_Con
Post by J_Con »
@gpaolo2kn yeah it's a straight fit
J_Con
Post by J_Con »
A closer look at the options on the new clusterImageImageImageImageImage
Sent from my SM-T813 using Tapatalk
J_Con
Post by J_Con »
Plastics and headliner removed to colour match.
I also used scuff paste and a scotchbrite pad for the plastics first
U-pol plast adhesion promoter and U-pol plast dark grey for the plastics and autobrite dye for the headliner.
Touran centre console fittedImageImageImageImageImageImageImage
suzierobs
Post by suzierobs »
Looks great 👍
When you fitted the engine cover, did you need any fixings, or did it just clip straight on?
I’ve got the same engine (I think), here’s a pic - would I need to get fixings or just the cover?
Thanks in advance for your advice 😊
Engine bay
Engine bay
J_Con
Post by J_Con »
@suzierobs thanks!
The oil ring isn't needed to make the cover fit but stops spilt oil so worth doing imo, part number is 03L133287, and you'll also need 2 Mounting Ball heads, part number is 03L103164
J_Con
Post by J_Con »
Bad snow last year and soon as I took the van off the drive the coilover had snapped, can see how much lower the front is
