The Caddy Alloys Thread
RY_VW
Re: The Caddy Alloys Thread
Post by RY_VW »
AUSCaddyMaxiLife wrote: Sun Jul 18, 2021 11:41 pm Do you bother with keeping the rolling diameters the same or just use GPS for a speedo?
I have and would advise it, using gps all the time seems like a pain :lol: there lots of combinations for you to keep it the same so your alloy choice wont be limited 8)
More to follow 8)
RY_VW
Post by RY_VW »
@Ade16 use https://www.willtheyfit.com/ to see how alloys will sit compared to your existing set up, for 18 and a width of 8j people tend to like a et45 off set, anywhere around that I'm sure you'dbe safe(do double check though), I've got 7.5j and et51 on mine and only stick out an extra 5/6 if I remember correctly so to me its perfect 8) and for your search I'd go for anything under the vag group for what size you want and just see what offsets are. I ended up knowing what models have which offsets and all sorts by the time id finished :lol:
More to follow 8)
veedubgub
Post by veedubgub »
Anyone know what wheels these are?
Sent from my E5823 using Tapatalk
RY_VW
Post by RY_VW »
@veedubgub
VW Seattle 8)
More to follow 8)
veedubgub
Post by veedubgub »
veedubgub
Post by veedubgub »
Got one more (sorry)
Anyone able to put a name to these?
RY_VW
Post by RY_VW »
@veedubgub I dont know the style name but theyre vw eos alloys ;)
More to follow 8)
veedubgub
Post by veedubgub »
Thanks again @RY_VW
Possibly Adelaides as i got a few results back with that name when searching for eos wheels
Russ74
Post by Russ74 »
Fitted these Audi B7 DTM wheels 8J ET 43 with 225/40/18 Tyres Image
Exuptoy
Post by Exuptoy »
Only read as far as P20 and so far haven’t seen my rims in here. They’re genuine VW EOS/Passat ET47 7.5x18 Solitudes. Very similar to the 19” R32 rims but the spoke detail is slightly different.
Needs lowering now.
Mine were powder coated in Iodine colour(🤷🏻‍♂️) which is basically a metallic anthracite colour.
Carolthecaddy
Post by Carolthecaddy »
How do I figure out what wheels will fit?
RY_VW
Post by RY_VW »
@Carolthecaddy use https://www.willtheyfit.com/ for defence with offsets and widths, centre bore is 57.1 and stud pattern is 5x112. I think the most favoured setup is 8j and around et 42 but theres lots of setups people have got on if you have a read through this thread you'll see. I've gone with 7.5j width and et 51 and think it's perfect 8) do you want aftermarket or vw group? If you go vw group most golf,touran,passat,leon,Octavia and the likes will go on 8)
More to follow 8)
Stricky
Post by Stricky »
Mastakillahkungfu wrote:Only got one photo of banded steels. Image
Anyone have any idea of what steels these are and what size they have been banded to?
Cheers Image
JimBob3000
Post by JimBob3000 »
Does anyone have any examples of either Mk7 GTI clubsports or Mk6 GTI Edition 35's on a black caddy?
Giddy
Post by Giddy »
@Stricky
Custom banded steel wheels. You can chose pretty much any size you want 15-19"
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
