My ex British Gas conversion
Love the setup in the back! done a cracking job there
- robblowen
@gingerrob sorry man, I didn't see your question! Good job I spotted your other seatbelt post! You managed to get your seatbelts sorted?
- robblowen
@TK2192 cheers man, its getting close to where I want it inside, need to start thinking of the outside next.
Yes thank you glad you posted as I was not happy with the long bolts and wedge washers way of fitting so did a similar thing to you though used a hole saw and some laser cut steel discs to button it back up, bit fiddly but happy with the factory look will post some pics on mine when I'm done and happy with it ...robblowen wrote:@gingerrob sorry man, I didn't see your question! Good job I spotted your other seatbelt post! You managed to get your seatbelts sorted?
- robblowen
@gingerrob nice one, glad you got it sorted dude
- richyd711
Where about did you run your wires for the speakers? Also what size speakers are you running?robblowen wrote:Got the rear speakers fitted and wired in as well. Decided to change where I located them front inside the rear doors to just behind the rear seats. This makes the sound better and meant the were easier to mount.
Great looking build so far can't wait to see more progress
Reason: reduced the quote
Some great inspiration here mate, love your work!
Excellent build.
- robblowen
Sorry for not replying lads, I've not touched the van for ages and barely been on the forum either! I ran the wiring along to edge of the roof lining as originally I was going to the upper rear corners, then dropped down inside the c pillars. If you're going to fit them in the same place i would think along the sills/under the step would be a lot less faff. As for size I can't remember off the top of my head, similar to the fronts, may even be the same size? That's for the comments guys, hope its given you all some good ideas!
- robblowen
So I finally got a few hours on the van, I touched up a load of stone chips on the bonnet which were annoying me, I've just cut them all back. Should get chance to give it a wash and proper polish tomorrow. It's not perfect but you can kind of see from the pics it looks 10 times better!
excellent pics really useful thanks, ive tracked down a floor panel through tps but can't figure ot the part number for the black hinge and brackets to bolt-on can you help please
- robblowen
@SimonDBS cheers mate, which bits do you mean, the brackets for the rear seats?
If you're after the brackets for the rear seats everything you need should be on here, I think.
https://volkswagen.7zap.com/en/rdw/cadd ... 883020/#50
- robblowen
Finally got around to fitting my door handle illumination. If I'm honest it's not as bright as I was hoping, so I need to have a play about with it, not sure if it's the positioning or something else, but you can't really see the light in your own door handle, only the handle opposite even when turned right up?
- robblowen
Also picked up some foglights, just need to sort the wiring to get them working, but they definitely freshen up the front end. Next job is to cut and bond the awning rail, just need a couple dry days forecast.
looking good Rob. Can i ask what rail you are going to use? Looking at a couple different ones recommended by guys on here. Also what product do you use to cut back your bonnet? Mine needs some serious TLC.
