Katiecaddy
Post by Katiecaddy »
They look spot on suit the colour as well :D
wildybeast
Post by wildybeast »
Me to.Image
RY_VW
Post by RY_VW »
@Katiecaddy thankyou:) chuffed with them :D
More to follow 8)
Katiecaddy
@RY_VW the reflex silver really suits silver alloys, ours is silver on silver, I would have liked black on our maxi like on our Volvo, there a Matt/satin finish on the Volvo, with a diamond cut finish on the face, only thing is the black finish shows any sign of brake dust and contamination. I always find black alloys look small against the black of the tyre as well.
When I fit the alloys on the van I gave them a good coat of poor boys wheel sealant. Brake dust just rinses off now and they always look clean.
@ wildybeast they look mint as well. Very similar to our Volvo wheels
dikkies101
Post by dikkies101 »
Hello what do your guys think of these..they 19's for a Maxi !! Image
Sent from my ELS-NX9 using Tapatalk
rbu_tuninq
Post by rbu_tuninq »
Working on a headlight morimoto xenon projectors retrofit to mk4 :)
Katiecaddy
Let us see the progress with the xenon retrofit for the mk4
rbu_tuninq
wildybeast
Thanks for the pics. Great work Ime just about to do the same with my morimotos . Which and where did you get the shrouds from.? How are you wiring the Headlight flash as i think they wont be instant on .My idea was to use DRL or Fogs s as flash.Keep us updated.
Treads
Post by Treads »
@Dickies
I like them
2012 Caddy, 1.6 TDi (needs a chip tune!)
2k12 Natural grey,
102PS,
Side rail cover,
Coilovers & Axle flip,
18” black alloys,
Touran seats, bases, drawers & arm rest.
Colour coded door handles,
Colour coded Touran bump strips,
Auto lights upgrade,
LED interior lights,
Touran mirrors (not yet folding!)
MFSW,
Needle sweep on start-up,
Westfalica removable tow bar & OEM electrics,
Genuine VCDS available if anyone is nearby...
Ripley55
Post by Ripley55 »
Yes, I'd be interested in seeing that too on a MK4 :D
rbu_tuninq
I'm using morimoto d2s 5.0 .
Shrouds are 3" ...vw r32 design or something similar.
...they are all from the retrofitsource .
High beam will be on same projector with actuator .
I've got some relay adaptor wiring from the original h4 3 pin plug to : a. D2s bulb hid
b. High beam actuator
Flash should be through the relay wiring
https://ibb.co/sWZXstr
If low beam voltage is missing... on flash it will power both....low beam and actuator.
Kaddyken
Post by Kaddyken »
Our ex BG van has only done 36,000 miles but it's now 5 years old so yesterday for peace of mind, got the timing belt changed at our local garage. They also changed the water pump and gave it an oil & filter change. Drained the bank balance though :shock: :shock:
C Chis
Post by C Chis »
Fitted my colour coded R32 style bumper
Just need to sort out the lights, handle and badges now!
Katiecaddy
@c chis loving that bumper it looks spot on.
