- Peng
@the swan fiend no problem, really good little addition and super simple
Yetiman25
@ peng Me too cheers for link
I.D.S.
Reach out to Jack at SSS and he’ll be able to help with whatever you need. They do mail order.Katiecaddy wrote:@the swan fiend
Where/ what’s the best type of filter do you think?
I.D.S.
If you aim for a refillable DI vessel for your final (by hose) rinse and i use the small carbon one for wash bucket and pump sprayer fills .the swan fiend wrote:Hi Katie. Not sure what one I’ll get at the moment. I’ve seen this one on eBay. You can also get the refills too.
https://www.ebay.co.uk/itm/114247072743
Also this one.....
https://www.iodetail.com/products/iodet ... ter-filter
I feel I need to do more research first though. I’m open to suggestions and recommendations too.
vizidomar
Fitted a center storage wiith lid
Tapatalkkal küldve az én COL-L29 eszközömről
Katiecaddy
@I.D.S. thanks for that il check it out.
@vizidomar I’m well jealous of that hinged lid on your LHD mk4, wishVW had made an option for the right hand drive mk4
- Rohtang666
Fitted mk6 golf multifunctional steering wheel in 63 plate highline caddy.
What extra stuff do I need to do to make it work?
Does it need a new SWCM and air bag harness along with coding?
Thanks in advance.
Thanks in advance.
- Crazy7ony
R32 / S3 brakes fitted
- Azz03
@viraleye how hard was it to get the plates in even with it carpeted as mines fully carpeted and the seat belts is my next task. Thanks
- Azz03
Not today but yesterday lol Finally got round to fitting new mk5 golf gti front shocks and eibach lowering springs after fighting with the drivers side as it was a right pain to get into the back of the hub then I noticed a school boy error by leaving the brake hose the wrong side of the strut
good job brakes are coming off as well lol hopefully get the rears done today weather permitted
Robert24
Good evening,Azz03 wrote: ↑Sun Nov 01, 2020 8:55 am Not today but yesterday lol Finally got round to fitting new mk5 golf gti front shocks and eibach lowering springs after fighting with the drivers side as it was a right pain to get into the back of the hub then I noticed a school boy error by leaving the brake hose the wrong side of the strutgood job brakes are coming off as well lol hopefully get the rears done today weather permitted
What sort of drop are you expecting to get from the gti front set up?
Robert
- Azz03
@robert24 these are 60mm eibach lowering springs mate on mk5 golf gti front shocks
- davinci
@Azz03 what is the benefit of mk5 shock over the caddy ones?
@Azz03 you've built that strut up without a dust boot. That's not going to last very long like that as it'll destroy the shock seals.
- Azz03
@davinci the guy who built my engine is a vw specialist and works mainly in caddy’s so he knows a lot about them. So he told me to go for mk5 gti shocks as the lowering springs sit better and are a more comfortable ride on less of a crash feeling over pot holes.
@doc I did think about putting new ones on but every set of coil overs I’ve ever had haven’t had any cover over the main strut ?
